Cisco DNA Center 1.2.0.1021 not able to run Automation - Intelligent Capture
Hi all.
I am using Cisco DNA Center running software 1.2.0.1021. I am trying to use Automation - Intelligent Capture. When I try to access that function in Assurance page, the Client Intelligent Capture is grayed and the AP Intelligent Capture says it hasnt been installed.
Am I need to upgrade the software first to access intelligent capture?
Thank you.
Dan Rowe
There is an intelligent capture package which needs to be deployed in order to utilize Intelligent Capture. Can you provide the following output from your DNA center CLI:
maglev catalog package display
maglev package status
Thanks!
Hi Danirower.
Here is the output you asked. Thank you.
Best regards,
Lazuardi
