Cisco DNA Center for seperate network
missengineer
Hi All,
I have question about DNA center.
I have designed 2 seperate network with same Cisco products for different systems. But location will be same. I mean products will be on the same panel but connected system will be different. Supplier tells to us that we must use  2 DNA center for 2 seperate network because they are physically seperate. Is it necessary to use 2 DNA center? Can I manage  these networks with one DNA center?
Hi @missengineer
 As long as they have connectivity of course you can. Even they were in different location.
You can create different sites and apply different network profiles to different sites.
5 Replies 5
Hi @missengineer
Hi Miranda,
You mean that I can manage my completely seperate network with 1 NMS system? Just 1 DNA server and software will be enough?
Am I right?
that´s right. Just to give you one example, I used to manage the DNAC for a bank with 4.000 branches and 50 corp buidings...all of them in the DNAC.
You just need to create different sites.  Each line in read below can be a physical location.
Thank you very much Miranda for reply and shared pic.
It is clear now that you mean it doesnt matter how many I have different Cisco device and seperate network. We can create site on DNAC for each them. So 1 DNAC is enough.
It is. You will be required more server if you infrastructure grows too much and you end up having a hundreds of sites.
