Cisco DNA-Essentials license - how to activate?
neofit.solovan
Hi all,
So I have a stack of 2 x Catalyst 9300 and 2 x C9300-DNA-E-48= licenses.
I'm a bit confused on how to activate these licenses. Everything clear with the old ones, but the new versions, are just RTU ?
N
5 Replies 5
vijha
Please follow the below snippet, taken from this url:
https://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/dna-center/nb-09-dna-center-data-sheet-cte-en.html
Licensing and ordering
To enable the Cisco DNA Center features listed in Tables 1 and 3, you will need one Cisco DNA Essentials or Cisco DNA Advantage license for each network device. Both of these licenses are available for purchase with Cisco ONE Software or a la carte. Please contact your Cisco sales representative for the Cisco DNA Center Ordering Guide.
See how Cisco ONE makes software buying simple: Cisco One Software.
More documentation on Cisco One Software:
https://www.cisco.com/c/en/us/products/software/one-software/index.html?CAMPAIGN=cisco%2Bone&COUNTRY_SITE=us&POSITION=vanity&REFERRING_SITE=vanity&CREATIVE=go%2Bone
Vibha Jha
Cisco Sales Acceleration Center.
Thank you, but this is not what I was looking for.
ammahend
Yes its RTU, you will configure following to accept RTU from CLI
license right-to-use activate network-essentials all acceptEULA
license right-to-use activate addon dna-essentials subscription all acceptEULA
 since you have essential license, to see what you can all you can do with essential licenses (provided you have DNAC as well), see slide 25 here
https://www.cisco.com/c/dam/en/us/products/collateral/software/one-subscription-switching/dna-licensing-switching-subscription-bdm.pdf
to verify licenses you can run command
show license right-to-use usage
you will need a reload for the license to take effect.
Read more about License here
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-6/configuration_guide/sys_mgmt/b_166_sys_mgmt_9300_cg/b_166_sys_mgmt_9300_cg_chapter_011.html#concept_rdf_qtj_n1b
-hope this helps-
I thought that would be all but wasn't sure. Will bring it live in the next couple of days and confirm.
Cheers,
N
Great, have a good one.
-hope this helps-
