12-19-2019 06:26 PM - edited 12-19-2019 06:32 PM
Hi community users
The LAN Automation function of DNA does not work.
Device Name is well defined in the inventory
Last Sync Status is also managed.
However
Action-> Provision-> LAN Automation
Error Massage
Invalid CLI User defined for discoverd site
What should I check more ?
DNA Center : 1.3.0.109
Platform: C9500-16X
Software Version: 17.1.1
12-20-2019 09:48 AM - edited 12-20-2019 09:49 AM
Hey Mhhan,
Please note that 17.11.1 is not a supported device as of DNA version 1.3.1.4. Can you please downgrade to a supported version of code for the 9500 Catalyst switches, re-sync the device, and re-attempt the LAN automation task?
Also, make sure you have CLI credentials & SNMP community specified and selected for the site you are using for the LAN automation task:
-- Check DNAC GUI -> Design -> Network Settings -> Device Credentials -> Select the Site/Building you are using for the LAN automation job -> Is a CLI & SNMP entry selected?
DNA / SDA Compatibility Matrix:
If you are still facing issues after checking the suggestions above, please open up a service request with TAC so they can assist with troubleshooting this problem.
Best Regards,
