06-08-2021 12:16 PM
Dear All,
we've below BOM and want to use ISE, Prime Infrastructure and other services included in DNA premier but we want to make sure what additional components must be added to use those features and what exact features or services do we have apart from Layer 3 capabilities and please advise.
C9300-48U-A | Catalyst 9300 48-port UPOE, Network Advantage | pcs | 2 |
C9300-NW-A-48 | C9300 Network Advantage, 48-port license | pcs | 2 |
S9300UK9-1612 | Cisco Catalyst 9300 XE 16.12 UNIVERSAL | pcs | 2 |
PWR-C1-1100WAC-P | 1100W AC 80+ platinum Config 1 Power Supply | pcs | 2 |
PWR-C1-1100WAC-P/2 | 1100W AC 80+ platinum Config 1 Secondary Power Supply | pcs | 2 |
CAB-TA-EU | Europe AC Type A Power Cable | pcs | 4 |
C9300-SSD-NONE | No SSD Card Selected | pcs | 2 |
STACK-T1-50CM | 50CM Type 1 Stacking Cable | pcs | 2 |
CAB-SPWR-30CM | Catalyst Stack Power Cable 30 CM | pcs | 2 |
C9300-DNA-P-48 | C9300 48-Port DNA-Premier License | pcs | 2 |
C9300-DNA-P-48-3Y | C9300 DNA Premier, 48-Port, 3 Year Term License | pcs | 2 |
ISE-BASE-T | ISE BASE Term License | pcs | 50 |
ISE-BASE-TRK-3Y | ISE BASE Tracker Term 3Y | pcs | 50 |
ISE-PLS-T | ISE PLS Term License | pcs | 50 |
ISE-PLS-TRK-3Y | ISE PLS Tracker Term 3Y | pcs | 50 |
SWATCH-T | StealthWatch 1 FPS Term License | pcs | 200 |
SWATCH-TRK-3Y | ISE BASE Tracker Term 3Y | pcs | 200 |
CAT-DNA-P-ADD | Catalyst DNA Premier Add-On, Term Licenses | pcs | 2 |
CAT-DNA-P-ADD-3Y | DNA Premier Catalyst Add-on, 3 Year Term License | pcs | 2 |
PI-LFAS-T | Prime Infrastructure Lifecycle & Assurance Term - Smart Lic | pcs | 2 |
PI-LFAS-AP-T-3Y | PI Dev Lic for Lifecycle & Assurance Term 3Y | pcs | 2 |
C9300-NM-4G | Catalyst 9300 4 x 1GE Network Module | pcs | 2 |
NETWORK-PNP-LIC | Network Plug-n-Play Connect for zero-touch device deployment | pcs | 2 |
CON-SNT-C93004UA | SNTC-8X5XNBD Catalyst 9300 48-port UPOE, Network Adva | pcs | 2 |
06-08-2021 04:44 PM
Not sure we have understood your question correctly here - DNA premier - means you have a higher level of License.(which cover most of it)
i suggest contacting Local Cisco SE or partner before place an order, what is your requirement, (the kind of investment you putting above BoM) not cheap, so make sure you buying the right product for the right use.
06-09-2021 12:15 AM
Dear Balaji,
Thanks for your response,
what we want is to all the licenses included in the BOM majorly ISE and Prime Infrastructure but we want to be sure that what additional licenses and hardware are required to use those licenses like
Do we need to buy DNA center in order to use our licenses ?
can we buy ISE server only and use the ISE licenses included in the BOM ?
what additional hardware and licenses do we require in order to use Prime Infrastructure ?
regards
06-09-2021 06:43 AM
May be i can not give full view since what business want to do ? what kind of solution you building here. ?
So we do not want to missguide and make your money get wasted, where some soluition not required.
if you buying new DNAC, then you do not need Prime ( but DNAC not 100% of replacement ?)
DNAC is just orchestration tool for SD-Access deployment.
As per Access or Switches looking at there are not many switches here ?
Still i insists to contact Local partner to guide you better and your investment can be protected.
