Configuring Lightweight APs using Catalyst Center
Chris Terry
I know changing the name and other radio parameters is an option through the "Configure Access Points" workflow.
I was wondering if you could also configure things such as AP Group Name, AP mode, and AP location using Catalyst Center?
WLC: Cisco 5520
APs: C9120AXI-B and AIR-AP3802I-B-K9
balaji.bandi
check the matrix :
https://www.cisco.com/c/dam/en/us/td/docs/Website/enterprise/catalyst_center_compatibility_matrix/index.html
WLC 5520 is EOL so you need to hear towards Migrating to WLc 9800
Catalyst center and WLC 9800 is possible - if you looking for Migration.
BB
Torbjørn
You can't set these directly AFAIK. They will all be a result of where your AP is assigned and what settings you select under "network settings" > "Wireless"
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
