DNA/Catalyst Center Lost WLC 9800 Assurance After Upgrade to 2.3.7.6
ntwkrgr
Versions
  • WLC 9800-80: 17.12.4
  • DNA/Catalyst Center: 2.3.7.6
Symptoms
  • No assurance data is being sent/received from our WLC 9800 immediately following DNA Upgrade to 2.3.7.6.
  • show telemetry connection all on the WLC shows:
    • Index Peer Address Port VRF Source Address State State Description
      46711 X.X.X.X 25103 0 X.X.X.X Connecting Connection request made to transport handler
  • WLC Alert: Certificate renewal failed for trustpoint sdn-network-infra-iwan Reason : Failed to get ID certificate from CA server
Things I've Tried
  • Removing the DNAC-CA from the WLC & Re-adding it
  • Forcing a Telemetry Configuration push from DNA
  • Deleting, re-discovering, & re-provisioning the WLC9800
  • Confirmed the source interface is correct on the WLC's DNAC-CA trustpoint config
  • Manually re-added the sdn-network-infra-iwan cert to the WLC
  • Disabled revocation checks for the trustpoint
I'm stumped. I'm convinced it's some kind of certificate issue, but I'm not super experienced with certs so I'm starting to get in over my head. I've seen a few bug reports somewhat related to this issue, but no workarounds have been found. Before submitting a TAC case, I thought I'd check here to see if the community has experience fixing this.
Thanks!
ntwkrgr
Adding additional info:
I've run through this page, though admittedly, a lot of what's in here is new to me: https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/dna-traffic-telemetry-appliance/217044-troubleshoot-no-assurance-data-from-wlc.html
Also, this is one of the similar bug reports I found (Though our WLC is not an eWLC): https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvr98535
maflesch
At this point I would open a TAC case. This could be more of an issue with the ios-xe collector establishing the connection than it is a cert issue on the WLC.
jdeibel
Hello, I am experiencing a similar issue with a pair of 9800s and tried many of the same things.
I'll be opening a TAC case regardless, but do you recall what the resolution was for your issue? Thanks.
