DNA Center 2.3.5.5 schedule maintenance
Markus Truetsch
Hello: I want to schedule maintenance for a switch device. I does not work. It only gives you a Warning Pop Up, but no details. Has anybody had a simular problem? How could you solve it?
5 Replies 5
balaji.bandi
Can you post the screenshor for us to understand the issue ?
BB
In the previous DNA-Center version, it was possible.
[cid:image001.png@01DA5B62.A5FAF160]
I posted the screenshot. Do you need more information?
Tomas de Leon
You Screenshot did not attach correctly, but here is an example from 2.3.5.5.  It is working.
ScheduleMaintenance_01.pngScheduleMaintenance_02.pngScheduleMaintenance_03.pngScheduleMaintenance_04.pngScheduleMaintenance_05.png
Hello Tomas
Thank you for your example. I did exactly the same as in your example. But, I think the problem might be that my devices are not reachable.
If I configure a maintenance window for a device which is reachable, it works fine.
