DNA Center and ISE integration fails on Connecting to pxGrid
bjohnson04
My DNACenter and ISE integration is failing on step 4 - Connecting to pxGrid
The error is - Failed to connect to ISE node - invalid certificate received from ISE. Note: This might be due to Certificate Authority being disabled on ISE. Please check
DNA version is 2.2.3.5
ISE version is 3.0.0.458
Im pretty sure i've looked to make sure Certificate Authority is not disabled on ISE.
Sylvain_Che
Hi @bjohnson04,
Make sure your PXgrid certificate on ISE is signed by ISE internal CA, and not signed from your PKI/external CA. Then retry the integration.
This was a culprit I faced a few times already.
Sylvain.
