06-19-2020 09:53 AM
Is it possible to temporarily disable monitoring on a device that may need to go offline due to a planned outage or maintenance? I'm new to this community, so in advance thank you for any replies and input. - JD
06-19-2020 11:51 AM
06-19-2020 02:15 PM
Thanks for the suggestion. I did disable telemetry on the device that was taken offline for testing purposes. I was hoping it would suppress the device unreachable and wsa export failure email notifications but it didn't work.
09-27-2021 06:02 PM
Hi Mike, I don't see those options available in the current DNAC GUI (2.2.3.0 here)
If you meant Design/Network Settings/Telemetry then there are no NADs visible in this view for me, only sites and the common collection settings.
06-18-2021 12:08 PM
Hello dvnetops,
Did you find a solution to this...same boat.
MT
06-25-2021 10:18 AM
Cisco DNA assumes that network devices it manages are supposed to be always on and reachable. The only options you have today, that I can think of are (not ideal):
- Remove device from inventory
- Use the "Ignore" option on the Issues that arise when you shut down a network device
If you have a good use case for putting a device in some sort of "suspension" mode, please feel free to submit a Make a Wish from the Help menu (the question mark icon in the GUI).
12-08-2021 02:24 AM
"if you have a good use case"...
This is such a basic missed feature for the real world.
12-08-2021 11:08 AM - edited 12-08-2021 11:12 AM
This feature (called Maintenance Mode) will be coming in an upcoming release. Not sure yet if it's the next one, coming very soon, or the following.
03-15-2022 06:07 PM
I can't wait for this feature. Glad I found this thread, it was driving me crazy:)
