DNA Center Installation Problem
SecurityEng99
Hello
I'm trying to install Cisco DNAC on ESXI with recommended resources, but I have been run into fun issues. Right now I have DNAC version 2.3.5.5 is running, but I see this error showing on the top of the GUI
Automation and Assurance services have been temporarily disrupted. The system is working to restore this functionality.
and when I click fore more details, I see the following:
ggregationjobs
ndp
Down
5.0.178
pipelineruntime-taskmgr-assurance-1
ndp
Down
5.1.64
pipelineruntime-taskmgr-assurance-2
ndp
Down
5.1.64
pipelineruntime-taskmgr-base
ndp
Down
5.1.64
pipelineruntime-taskmgr-data
ndp
Down
5.1.64
pipelineruntime-taskmgr-spa-apps
ndp
Down
5.1.64
pipelineruntime-taskmgr-timeseries
ndp
Down
5.1.64
release-job
maglev-system
Down
1.0
distributed-cache-service
fusion
Down
7.1.616.60023
file-service
fusion
Down
7.1.616.60023
messagecatalog
fusion
Down
2.1.616.60023
task-service
fusion
Down
7.1.616.60023
telemetry-service
fusion
Down
7.1.616.60023
cnsr-reasoner
fusion
Down
7.28.616.210007
apic-em-inventory-manager-service
fusion
Down
7.1.616.60023
apic-em-network-programmer-service
fusion
Down
7.1.616.60023
apic-em-pki-broker-service
fusion
Down
7.1.616.60023
config-archive-service
fusion
Down
7.1.616.60023
data-cob
fusion
Down
7.1.616.60023
grouping-service
fusion
Down
7.1.616.60023
ipam-service
fusion
Down
7.1.616.60023
licensemanager
fusion
Down
2.1.616.60023
maintenance-service
fusion
Down
7.1.616.60023
messaging-persistence-scanner-service
fusion
Down
7.1.616.60023
network-design-service
fusion
Down
7.1.616.60023
network-validation-service
fusion
Down
7.1.616.60023
networkvalidationpyservice
fusion
Down
2.1.616.60023
orchestration-engine-service
fusion
Down
7.1.616.60023
scheduler-service
fusion
Down
7.1.616.60023
search-service
fusion
Down
7.1.616.60023
Please advise
6 Replies 6
marce1000
 - Check DNAC VM resources being used with the hypervisor from ESXI and or try to increase memory for the VM ,
 M.
Tomas de Leon
You mention that you are trying to install Catalyst Center Release 2.3.5.5 on ESXi. This is problem #1. This is not supported. Although some folks may get this to work, you are or can waste a lot of time in trying to get this work.
The official release for Catalyst Center on ESXi is 2.3.7.4 and is GA. You can download the OVA and deployment on ESXi with no issues (as long as your resources meet specifications). I would advise using the officially supported release for Catalyst Center on ESXi is 2.3.7.4.
SecurityEng99
tried to use the OVA file 2.3.7.4 and I got error below
Failed to deploy OVF package. Cause: A general system error occurred: Transfer failed: Invalid response code: 500.
Any idea about that ?
- What version of vsphere or vcenter are you using?
- In order to make things happen a little faster and smoother, I added the OVA to the Content Library on vcenter first. Then deployed from there.  If you did not use content library, try that method.
- also verify the md5sum on OVA after you downloaded from software.cisco.com
- What version of vsphere or vcenter are you using?   Version 8.0.2.0 and md5sum  looks good. I tried the Content Library as well and no luck.
SecurityEng99,
The error could be related to different causes. You mentioned that the transfer failed in the original post. This is why I suggested the Content Library method. This would eliminate the transfer issue since already in your VMWare enironment.
If you select a new vm from the OVA in the Content Libary and it fails. The next step would look into the vmware logs to see what the exact messages are in regards to the failure.
It is hard to determine without logs and looking thru some of the configuration. The best course of action is to open a Cisco TAC Case so the TAC engineer can properly assess your issues.
Without Logs this is all guess work.
