10-29-2018 02:45 AM - edited 03-08-2019 05:28 PM
I was designing SDA solution and came across one query "Is it mandatory to deploy ISE in the same premises with DNA center while integration or will it work if ISE can be at different country and DNA Center is at another country. Is it possible to integrate into this scenario?
Solved! Go to Solution.
10-29-2018 12:25 PM
10-29-2018 08:56 AM
10-29-2018 12:23 PM
Thanks Gaur to reply.
To add further, in my scenario the ISE is in Europe n DNA center in India hence the min latency expected would be app. 125 ms. Now having this much of latency will ISE work with DNA center?
In my opinion, it will as the authentication or SGT data is not much and can be manageable.
Kindly suggest what do you advise on this.
10-29-2018 12:25 PM
10-29-2018 12:27 PM
11-01-2018 07:03 PM
Are you planning do Fabric also ? where are the endpoints and access switches located ?
