DNA Center integration with ISE
manisharora1432
I was designing SDA solution and came across one query "Is it mandatory to deploy ISE in the same premises with DNA center while integration or will it work if ISE can be at different country and DNA Center is at another country. Is it possible to integrate into this scenario?
It should be fine, just make sure DNAC can reach PAN/SAN/PSN/Pxgrid nodes.
5 Replies 5
Gaur Samal
We can have ISE integrated even if it is another country, its just that you need to make sure latency is not an issue. because of you have high latency, then you may face issues in integration or client auth.
Thanks Gaur to reply.
To add further, in my scenario the ISE is in Europe n DNA center in India hence the min latency expected would be app. 125 ms. Now having this much of latency will ISE work with DNA center?
In my opinion, it will as the authentication or SGT data is not much and can be manageable.
Kindly suggest what do you advise on this.
Sure..Thanks..:)
Cheers!!
ammahend
Are you planning do Fabric also ? where are the endpoints and access switches located ?
-hope this helps-
