DNA Center - Purge old rca bundles
mbrandon32
Is there any way to purge or delete old rca bundles?
Logging in with maglev doesn't give you the appropriate rights as the files are owned by root.
Preston Chilcote
Try with sudo:
$ sudo rm /data/rca/maglev-x.x.x.x-rca-2020-07-13_10-48-06_UTC.tar.gz
Preston Chilcote
Try with sudo:
I swore I tried that before but it seems I may not have. Worked like a charm. Thanks!
