04-28-2022 03:01 AM
Upgrading a DNA Center in 2.1.2.6 version from system version 1.5.279 to 1.5.288 stops at 60% in phase 7:
maglev system_updater update_info
System update status:
Version successfully installed : 1.5.279
Version currently processed : 1.5.288
Update phase : failed
Update details : Updating node x.x.x.x failed
Progress : 60%
Updater State:
Currently processed version : 1.5.288
State : FAILED
Sub-State : INSTALLED_HOST_COMPONENTS
Source : system-updater
Abort pending : False
We also tried to delete previous downloaded packages as recommended in the DNA Center upgrade guide with:
for pkg in $(maglev package status -o json | jq -r '.[] | select(.available!="-") | [ .name,.available | tostring ] | join (":")'); do maglev catalog package delete $pkg 2>/dev/null; done
but the result is the same.
This is the error in the system updater log:
{"asctime": "2022-04-25 17:15:18,039", "timeMillis": 1650906918.03956, "filename": "node_updater.py", "funcName": "_wait_for_node_update_completion_helper", "levelname": "ERROR", "levelno": 40, "lineno": 804, "module": "node_updater", "msecs": 39.56007957458496, "message": "Got completion notification for phase (7): Node x.x.x.x version 1.5.288 state FAILED node-phase 7 phase 7", "name": "node-updater", "pathname": "/opt/maglev/lib/python3.5/site-packages/system_updater/node_updater.py", "process": 136, "processName": "MainProcess", "relativeCreated": 494022.76253700256, "thread": 139664920917760, "threadName": "Thread-13", "level": "ERROR"}
{"asctime": "2022-04-25 17:15:18,040", "timeMillis": 1650906918.0401087, "filename": "system_update_orchestrator.py", "funcName": "process_system_updater_requests", "levelname": "ERROR", "levelno": 40, "lineno": 428, "module": "system_update_orchestrator", "msecs": 40.108680725097656, "message": "\nStatus: 1/Updating node x.x.x.x failed\n", "name": "system-updater", "pathname": "/opt/maglev/lib/python3.5/site-packages/system_updater/system_update_orchestrator.py", "process": 136, "processName": "MainProcess", "relativeCreated": 494023.3111381531, "thread": 139666200835840, "threadName": "MainThread", "level": "ERROR"}
{"asctime": "2022-04-25 17:15:18,047", "timeMillis": 1650906918.0473998, "filename": "k8s_proxy.py", "funcName": "inner_wrapper", "levelname": "WARNING", "levelno": 30, "lineno": 110, "module": "k8s_proxy", "msecs": 47.39975929260254, "message": "Exception while getting kubernetes objects (<pykube.http.HTTPClient object at 0x7f068a0ca128>): ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))", "name": "root", "pathname": "/opt/maglev/lib/python3.5/site-packages/system_updater/common/k8s_proxy.py", "process": 136, "processName": "MainProcess", "relativeCreated": 494030.6022167206, "thread": 139664409224960, "threadName": "Thread-17", "level": "WARN"}
I know that ideally I should open a TAC case but this is an old Lab environment and unfortunately I don't have TAC support.
Any clues?
Thank you,
Helena
Solved! Go to Solution.
04-29-2022 03:19 AM
update:
I ran a maglev-config update wizard just to add a static route, and after that I tried the upgrade again: this time it worked fine:
Version successfully installed : 1.5.288
Updater State:
Currently processed version : NONE
State : IDLE
Sub-State : NONE
Details : The system has been successfully updated
I suppose than restarting the nodes helped.
Let's see how it goes now all the path to version 2.3.3..
Cheers.
04-28-2022 06:33 AM
kubectl get nodes
All nodes are Ready?
04-28-2022 09:41 AM
What version is your Cisco DNA center currently running? Depending on what code it is on currently, you may be able to run an AURA report which basically performs various health checks for your Cisco DNA Center. You may be able to identify what is causing the upgrade failure by checking the results of the AURA report.
Here is a link to the AURA report which provides step-by-step instructions of how to run it:
If your Cisco DNA center is running on code older than 2.x, you may be better off with performing a re-image on the latest 2.2.3.5 Cisco DNA Center. This can potentially save you several hours by re-imaging instead of upgrading as upgrading from pre-2.x code to 2.2.3.x will require multi-step upgrade.
04-28-2022 10:34 AM - edited 04-28-2022 10:35 AM
For the node, it seems to be ok:
kubectl get nodes
NAME STATUS ROLES AGE VERSION
192.168.x.x Ready master 346d v1.15.3-cisco
And for the version, it's 2.1.2.6, and I already ran the report but it doesn't help very much. The only warnings about the upgrade are:
Warning:Downloading a medium test image of size 150MB was aborted as it took > 30sec. Please in
crease the bandwidth to the cloud as this can slow down a DNAC upgrade. Over 10GB of software is
downloaded during an upgrade.
Warning:Downloading a large test image of size 650MB was aborted as it took > 130sec. Please in
but the update doesn't fail in the downloading phase.
Re-imaging the system can be an option but, don't we need to contact Cisco TAC for that?
Thank you very much for you answers.
Helena
04-28-2022 10:48 AM - edited 04-28-2022 10:49 AM
Run this command to see if you dont have any expired certificate:
sudo maglev-config certs info
Recently I had to upgrade 10 cluster with 3 nodes each due Log4J vulnerability. Same scenario 2.1.2.6 to 2.1.2.8
It turned out that only 2 cluster upgrade by itself and 8 with TAC and BU.
04-28-2022 11:01 AM
No, it is not required to work with TAC to re-image the Cisco DNA Center assuming you have access to download the latest ISO from software.cisco.com. You can follow these steps to re-image the appliance:
04-28-2022 11:36 AM
Certificates are also ok:
$ sudo maglev-config certs info
certificate start date end date
credentialmanager.pem Mar 26 02:34:08 2022 GMT Mar 26 02:34:08 2023 GMT
kong.pem Mar 26 02:34:08 2022 GMT Mar 26 02:34:08 2023 GMT
kube-worker-1.pem Mar 26 02:34:08 2022 GMT Mar 26 02:34:08 2023 GMT
maglev-registry.pem Mar 26 02:34:08 2022 GMT Mar 26 02:34:08 2023 GMT
apiserver.crt May 17 09:45:50 2021 GMT Mar 26 02:30:04 2023 GMT
apiserver-kubelet-client.crt May 17 09:45:50 2021 GMT Mar 26 02:30:05 2023 GMT
front-proxy-ca.crt May 17 10:53:00 2021 GMT May 15 10:53:00 2031 GMT
front-proxy-client.crt May 17 10:53:00 2021 GMT Mar 26 02:30:05 2023 GMT
admin.conf May 17 09:45:50 2021 GMT Mar 26 02:30:06 2023 GMT
scheduler.conf May 17 09:45:50 2021 GMT Mar 26 02:30:07 2023 GMT
controller-manager.conf May 17 09:45:50 2021 GMT Mar 26 02:30:07 2023 GMT
I'll start considering the re-imaging process, and try to get Cisco support in parallel.
Helena
04-28-2022 11:48 AM
Yeah, also think is the right decision. Good Luck!
04-29-2022 03:19 AM
update:
Updater State:
State : IDLE
Sub-State : NONE
Cheers.
