DNAC access point heat map layout
MC9
Hi all,
I am currently rolling out DNA center and have run into an issue. At one location I have a floor plan from the install team showing the location of all 100 access points. However, the APs are not labeled. I have imported the Cisco 5520 WLC and 3802 APs into DNA Center. Is there anyway for me to determine the correct AP is placed in the correct location on the floor plan?
Thanks!
-MC9
Dan Rowe
Unfortunately, no there is not. If you have the access points placed on the floor map in Prime Infrastructure, you can export that data from Prime Infrastructure into Cisco DNA Center. If this is not an option, the only way for you to be able to tell if the access points are placed correctly is by turning on the AP LED from the WLC and physically identifying the AP on the floor by the flashing LED.
