03-03-2025 01:28 AM
1. lldp api doesn't appear to report lldp neighbors if that neighbor is not managed by DNAC. Is that true ? Has anyone faced same issue ?
2. Is there an API in DNA, that can give the Fdb entries for switch devices managed in DNAC?
Thanks in Advance,
Senthil
03-03-2025 10:00 PM
Hello @SenthilS
Here are the answers to your questions regarding Cisco DNAC APIs and their behaviour:
Q. 1) Does the LLDP API report LLDP neighbors if the neighbor is not managed by DNAC?
Q. 2) Is there an API in DNAC that can provide the FDB (Forwarding Database) entries for switch devices managed in DNAC?
Hope This Helps!!!
AshSe
Community Etiquette:
03-04-2025 01:57 AM
1. Which API endpoint are you referring to here?
2. I unfortunately don't think so. You can probably use the command runner to extract this data and parse it with TextFSM or similar.
