DNAC(Catalyst Center) self signed certificate
SirEna
Hi, im planning to change our dnac's self signed certificate. if i have 3 nodes, do i need to change the cert per node? or changing the vip will do? thanks in advance
sorry I overlooked "self-signed"
take a look at the advice in this document
Cisco DNA Center Security Best Practices Guide - Cisco
section: Cisco DNA Center Hardening Steps
and section: Security Recommendation
  • Replace the self-signed server certificate from Cisco DNA Center with the certificate signed by your internal certificate authority (CA).
you can use a single certificate with VIP as CN and all hostnames in SAN field
for details see section: Generate a Certificate Request Using OpenSSL
this describes how to create the .csr and private key external from DNA center
and how to process this file into a file that can be imported in DNA center
pieterh
there should be a single cert for all nodes
but be aware check the SAN field of your current certificate
you may find all individual host-names included in this field
Hi Pieterch, thanks for the reply. if i login to the VIP the sanip field is empty. But if i login to 1 of the nodes, there are ip addresses populated in the sanip field. i.e. mgmt ips, enterprise ips,and those 169.254.x.x being used for clustering.  from which node should i generate the csr? another question is, what  should i choose from the following options:
Key Usage:
keyEncipherment
digitalSignature
nonRepudiation
keyCertSign
cRLSign
default selection are:
keyEncipherment and digitalSignature
extended key usage:
serverAuth
clientAuth
both are selected by default
thanks!
SirEna
at last, after going thru an ordeal and lots of processes i managed to update the cert =p. thanks for the ideas !
