DNAC Cluster 2 Device
longdv
Hi Everyone
I have 2 ADNC devices and 2 ISE devices located in DC, DR. Can I cluster between 2 DNAC and 2 ISE and how? Because currently the company's website is asking for cluster 3 devices
7 Replies 7
As far as I know, Cisco no recommend DNAC with 2 Site. Because when DNAC and VM DNAC at the DC are down, DNAC with DR cannot manage the device
Can you explain it to me?
Thanh you
I am only suggesting DNAC DR deployment. I am not sure you can Mix DNAC appliance with VM DNAC.
DNAC appliance + DNAC Appliance + DNAC Witness was the suggestion.
You should look at the design of reachability of both DC and latency requirement of DR.
Look at the Failure scenarios and IP level connectivity  to manage the devices.
BB
DC and DR are directly connected to each other with 2 100G links. When I create a Cluster between 3 DNAC (2 with DC (1 DNAC hardware 1 VM DNAC and 1 hardware with DR), will there be any problems?
i do not believe you can mix appliance and VM as per i know last i checked. anything change on new release check the release notes.
check HA requirement :
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2023/pdf/BRKOPS-2161.pdf
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/2-3-4/ha_guide/b_cisco_dna_center_ha_guide_2_3_4.html
BB
Thank you
My problem has been resolved
if no further information required, make it as close to help to refer other community members.
BB
