Multple Router types per Site
Hannes_Weber
I'm setting up router profiles in the Cisco DNA Center but I have multiple router types in a site.
As far as I understand the logic, you can have:
- one router type per Routing Profile
- one Routing Profile per Site
Is there a way to add multiple router types per site?
Am I missing something here?
DNA Center version is 2.3.5.5-70026
Torbjørn
You should be able to create a network profile with up to 10 devices. I am however not sure if it is possible to add more device types after creation of the network profile. https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/catalyst-center/2-3-7/user_guide/b_cisco_catalyst_center_user_guide_237/m_configure-network-profiles.html#id_60605
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Torbjørn
In a switching network profile, I can select multible devices types, but in a routing network profile, as far as I can see that, I can only select one device type.
The guide you linked is for version 2.3.7.x, but as I mentioned I'm still on the from my DNA Center recommended 2.3.5.x track... so it's just waiting for the new version, I guess...
Thank you!
