DNAC Image Repository not using Proxy
trickyg
I am recently upgraded to DNAC v2.2.2.6
I notice now that when I try and download image via Image repository it fails and (via TCPDUMP) have determined that this is due to the fact that it is not using the configured proxy and instead is attempting to connect directly to Cisco website.
Proxy config is OK and proved when I check DNAC Software Upgrades this goes via Proxy and works.
Is anyone else experiencing this behavior. It used to work fine in previous releases
trickyg
Found the issue - there is a setting EULA acceptance and this was unticked after the upgrade. Ticked and now uses the proxy for Image download
