06-20-2024 06:41 PM
Is there anyone encounter issue when do Cat9k IOS patching to version 17.09.05. Before start proceed with Software Update, there is readiness check result need to be done/pass. What we had encounter is the readiness check failed at stage "Flash check", eventhough we had confirm that the cat9k switch flash have more than enough space to proceed with IOS upgrade.
DNAC current version : 2.3.3.7 HF5
Current Cat9k switch IOS version : 17.06.04
Thanks everyone if can give some hints.
06-20-2024 10:42 PM
what is the full model of 9K ?
If you have enough space on the device reaching TAC can guide you better.
06-21-2024 07:11 AM
Model : C9410R
06-21-2024 07:12 AM
As we can see the storage capacity is more than enough to proceed with the IOS upgrade, either we use manual way or via DNAC
06-21-2024 12:28 PM
9410 SVL ?
06-23-2024 04:30 PM - edited 06-23-2024 04:30 PM
Hi bro,
There is no stack from the particular switch. The switch is standalone switch.
06-23-2024 07:08 PM
Post the complete output to the following commands:
dir
show boot
more bootflash:packages.conf | begin rp_boot
06-23-2024 11:46 PM
dir outpur
Directory of bootflash:/
293763 -rw- 242 Jun 23 2024 06:24:55 +08:00 smart_overall_health.log
293767 -rw- 33554432 Jun 21 2024 00:54:20 +08:00 nvram_config_bkup
163220 -rw- 33554432 Jun 21 2024 00:54:19 +08:00 nvram_config
163202 drwx 4096 Jun 20 2024 22:58:05 +08:00 .installer
163234 -rw- 0 Apr 18 2024 01:03:33 +08:00 dope_hist
424321 -rw- 17312 Apr 18 2024 01:03:33 +08:00 rdope_out.txt
424322 -rw- 89 Apr 18 2024 01:03:32 +08:00 rdope.log
163233 -rw- 16 Apr 18 2024 01:02:49 +08:00 nplusm-power
163225 -rw- 556 Apr 18 2024 01:02:44 +08:00 vlan.dat
293766 -rwx 2049 Apr 18 2024 01:02:29 +08:00 svl_ipc.tcl
163219 -rw- 134899 Apr 18 2024 01:02:29 +08:00 memleak.tcl
171361 drwx 4096 Apr 18 2024 01:02:19 +08:00 .prst_sync
163217 -rw- 396 Apr 18 2024 01:02:03 +08:00 boothelper.log
163215 drwx 4096 Apr 18 2024 01:02:02 +08:00 dc_profile_dir
163203 -rw- 666 Apr 18 2024 01:01:41 +08:00 bootloader_evt_handle.log
163224 -rwx 117 Mar 15 2024 00:53:11 +08:00 private-KS1
318241 drwx 4096 Sep 2 2023 16:36:25 +08:00 fp_cc_crash
399841 drwx 4096 Sep 2 2023 16:36:25 +08:00 tech_support
163206 drwx 4096 Sep 2 2023 16:32:35 +08:00 .rollback_timer
163237 -rw- 7488 Sep 2 2023 16:30:45 +08:00 packages.conf
244813 -rw- 48600136 Sep 2 2023 16:26:29 +08:00 cat9k-rpboot.17.06.04.SPA.pkg
244812 -rw- 9220 Sep 2 2023 16:25:42 +08:00 cat9k-wlc.17.06.04.SPA.pkg
244811 -rw- 17527812 Sep 2 2023 16:25:42 +08:00 cat9k-webui.17.06.04.SPA.pkg
244810 -rw- 31880200 Sep 2 2023 16:25:42 +08:00 cat9k-srdriver.17.06.04.SPA.pkg
244809 -rw- 61162500 Sep 2 2023 16:25:42 +08:00 cat9k-sipspa.17.06.04.SPA.pkg
244808 -rw- 37700616 Sep 2 2023 16:25:42 +08:00 cat9k-sipbase.17.06.04.SPA.pkg
244807 -rw- 689165316 Sep 2 2023 16:25:42 +08:00 cat9k-rpbase.17.06.04.SPA.pkg
244806 -rw- 9220 Sep 2 2023 16:25:42 +08:00 cat9k-lni.17.06.04.SPA.pkg
244805 -rw- 2098184 Sep 2 2023 16:25:42 +08:00 cat9k-guestshell.17.06.04.SPA.pkg
244804 -rw- 110449672 Sep 2 2023 16:25:42 +08:00 cat9k-espbase.17.06.04.SPA.pkg
244803 -rw- 19760140 Sep 2 2023 16:25:42 +08:00 cat9k-cc_srdriver.17.06.04.SPA.pkg
603848 drwx 4096 Aug 25 2021 00:05:30 +08:00 .dbpersist
603841 drwx 4096 Aug 24 2021 23:59:03 +08:00 Tbot
399875 drwx 4096 Aug 24 2021 23:58:51 +08:00 sys_report
399869 drwx 4096 Aug 24 2021 23:58:51 +08:00 ss_disc
293765 -rw- 5242880 Aug 24 2021 23:58:51 +08:00 ssd
163208 drwx 4096 Aug 24 2021 23:58:29 +08:00 .ssh
399863 drwx 4096 Aug 18 2020 21:50:24 +08:00 callhome
293761 -rw- 24 Apr 15 2019 22:56:43 +08:00 smd_debug.txt
163204 drwx 4096 Apr 10 2019 21:55:07 +08:00 core
204001 drwx 4096 Nov 23 2018 00:51:36 +08:00 onep
163222 -rw- 108134 Nov 23 2018 00:05:59 +08:00 pnp-tech-discovery-summary
163221 -rw- 35 Nov 23 2018 00:05:52 +08:00 pnp-tech-time
show boot output:
BOOT variable = bootflash:packages.conf;
MANUAL_BOOT variable = no
BAUD variable = 9600
ENABLE_BREAK variable does not exist
BOOTMODE variable does not exist
IPXE_TIMEOUT variable does not exist
CONFIG_FILE variable =
Standby BOOT variable = bootflash:packages.conf;
Standby MANUAL_BOOT variable = no
Standby BAUD variable = 9600
Standby ENABLE_BREAK variable does not exist
Standby BOOTMODE variable does not exist
Standby IPXE_TIMEOUT variable does not exist
Standby CONFIG_FILE variable =
"more bootflash:packages.conf | be rp_boot" output
boot rp 0 0 rp_boot cat9k-rpboot.17.06.04.SPA.pkg
boot rp 1 0 rp_boot cat9k-rpboot.17.06.04.SPA.pkg
iso rp 0 0 rp_base cat9k-rpbase.17.06.04.SPA.pkg
iso rp 1 0 rp_base cat9k-rpbase.17.06.04.SPA.pkg
iso rp 0 0 rp_daemons cat9k-rpbase.17.06.04.SPA.pkg
iso rp 1 0 rp_daemons cat9k-rpbase.17.06.04.SPA.pkg
iso rp 0 0 rp_iosd cat9k-rpbase.17.06.04.SPA.pkg
iso rp 1 0 rp_iosd cat9k-rpbase.17.06.04.SPA.pkg
iso rp 0 0 rp_security cat9k-rpbase.17.06.04.SPA.pkg
iso rp 1 0 rp_security cat9k-rpbase.17.06.04.SPA.pkg
iso rp 0 0 rp_wlc cat9k-wlc.17.06.04.SPA.pkg
iso rp 1 0 rp_wlc cat9k-wlc.17.06.04.SPA.pkg
iso rp 0 0 rp_webui cat9k-webui.17.06.04.SPA.pkg
iso rp 1 0 rp_webui cat9k-webui.17.06.04.SPA.pkg
iso rp 0 0 srdriver cat9k-srdriver.17.06.04.SPA.pkg
iso rp 1 0 srdriver cat9k-srdriver.17.06.04.SPA.pkg
iso rp 0 0 guestshell cat9k-guestshell.17.06.04.SPA.pkg
iso rp 1 0 guestshell cat9k-guestshell.17.06.04.SPA.pkg
iso bp 0 0 bp cat9k-rpbase.17.06.04.SPA.pkg
iso fp 0 0 fp cat9k-espbase.17.06.04.SPA.pkg
iso fp 1 0 fp cat9k-espbase.17.06.04.SPA.pkg
iso fp 0 0 fp_lni cat9k-lni.17.06.04.SPA.pkg
iso fp 1 0 fp_lni cat9k-lni.17.06.04.SPA.pkg
iso cc 0 0 cc cat9k-sipbase.17.06.04.SPA.pkg
iso cc 1 0 cc cat9k-sipbase.17.06.04.SPA.pkg
iso cc 2 0 cc cat9k-sipbase.17.06.04.SPA.pkg
iso cc 3 0 cc cat9k-sipbase.17.06.04.SPA.pkg
iso cc 4 0 cc cat9k-sipbase.17.06.04.SPA.pkg
iso cc 5 0 cc cat9k-sipbase.17.06.04.SPA.pkg
iso cc 6 0 cc cat9k-sipbase.17.06.04.SPA.pkg
iso cc 7 0 cc cat9k-sipbase.17.06.04.SPA.pkg
iso cc 8 0 cc cat9k-sipbase.17.06.04.SPA.pkg
iso cc 9 0 cc cat9k-sipbase.17.06.04.SPA.pkg
iso cc 10 0 cc cat9k-sipbase.17.06.04.SPA.pkg
iso cc 0 0 cc_spa cat9k-sipspa.17.06.04.SPA.pkg
iso cc 1 0 cc_spa cat9k-sipspa.17.06.04.SPA.pkg
iso cc 2 0 cc_spa cat9k-sipspa.17.06.04.SPA.pkg
iso cc 3 0 cc_spa cat9k-sipspa.17.06.04.SPA.pkg
iso cc 4 0 cc_spa cat9k-sipspa.17.06.04.SPA.pkg
iso cc 5 0 cc_spa cat9k-sipspa.17.06.04.SPA.pkg
iso cc 6 0 cc_spa cat9k-sipspa.17.06.04.SPA.pkg
iso cc 7 0 cc_spa cat9k-sipspa.17.06.04.SPA.pkg
iso cc 8 0 cc_spa cat9k-sipspa.17.06.04.SPA.pkg
iso cc 9 0 cc_spa cat9k-sipspa.17.06.04.SPA.pkg
iso cc 10 0 cc_spa cat9k-sipspa.17.06.04.SPA.pkg
iso cc 0 0 cc_srdriver cat9k-cc_srdriver.17.06.04.SPA.pkg
iso cc 1 0 cc_srdriver cat9k-cc_srdriver.17.06.04.SPA.pkg
iso cc 2 0 cc_srdriver cat9k-cc_srdriver.17.06.04.SPA.pkg
iso cc 3 0 cc_srdriver cat9k-cc_srdriver.17.06.04.SPA.pkg
iso cc 4 0 cc_srdriver cat9k-cc_srdriver.17.06.04.SPA.pkg
iso cc 5 0 cc_srdriver cat9k-cc_srdriver.17.06.04.SPA.pkg
iso cc 6 0 cc_srdriver cat9k-cc_srdriver.17.06.04.SPA.pkg
iso cc 7 0 cc_srdriver cat9k-cc_srdriver.17.06.04.SPA.pkg
iso cc 8 0 cc_srdriver cat9k-cc_srdriver.17.06.04.SPA.pkg
iso cc 9 0 cc_srdriver cat9k-cc_srdriver.17.06.04.SPA.pkg
iso cc 10 0 cc_srdriver cat9k-cc_srdriver.17.06.04.SPA.pkg
iso fp 0 0 fp_srdriver cat9k-cc_srdriver.17.06.04.SPA.pkg
iso fp 1 0 fp_srdriver cat9k-cc_srdriver.17.06.04.SPA.pkg
# -start- superpackage .pkginfo
# pkginfo: Name: rp_super
# pkginfo: BuildTime: 2022-08-14_09.01
# pkginfo: ReleaseDate: Sun-14-Aug-22-08:12
# pkginfo: .BuildArch: x86_64
# pkginfo: BootArchitecture: i686
# pkginfo: .BootArch: i686
# pkginfo: RouteProcessor: cat9k
# pkginfo: Platform: CAT9K
# pkginfo: User: mcpre
# pkginfo: PackageName: universalk9
# pkginfo: Build: 17.06.04
# pkginfo: .SupportedBoards: cat9k
# pkginfo: .InstallModel:
# pkginfo: .PackageRole: rp_super
# pkginfo: .RestartRole: rp_super
# pkginfo: .UnifiedPlatformList: passport,nyquist,starfleet
# pkginfo: CardTypes:
# pkginfo: .CardTypes:
# pkginfo: .BuildPath: /nobackup/mcpre/release/BLD-V17_06_04_FC1/binos/linkfarm/stage-cat9k/hard/rp_super_universalk9.x86_64
# pkginfo: .Version: 17.06.04.0.4912.1660492902..Bengaluru
# pkginfo: .InstallVersion: 1.0.0
# pkginfo: .InstallCapCommitSupport: yes
# pkginfo: .PKGID: 2dff99a663136ef91ac564cb179567d7b477b123
# -end- superpackage .pkginfo
