DNAC pnp DHCP
pholos
Hello everyone !
I'm trying to perform pnp on a switch using DNAC.  My switches can't get past autoinstall on DHCPv6.
I tried it many times before and it worked. I haven't changed my configuration.
Is there a way to deactivate autoinstall on dhcpv6 ?
Thank you :
pholos
@Flavio Miranda You're right it's the option. I removed the ; after 80 and it worked.
My bad
Thank you for your help
6 Replies 6
 Try to disable DHCPV6 on the switch "no ipv6 unicast-routing"
pholos
I already tried it but it didn't change anything.
When I looked at pnp trace, I had messages likes :
 pnp profile config unsuccesfull
no op 43 discovery
But I can see that the switch received an IPv4 address and the option 43 . This is the first time I get this problem,  I don't know what it means.
pholos
------------------ show pnp trace ------------------
[06/27/23 13:12:23.178 UTC 576 395] 24 _pcdd.orc: CCO is NOT waiting. Trying CCO discovery
[06/27/23 13:12:31.183 UTC 577 395] 23 _pcraci.wAr.psr: pnp_server not resolved
[06/27/23 13:12:31.183 UTC 578 395] 24 _pcdd.eRr.rai: Hostname resolution failed
[06/27/23 13:12:31.183 UTC 579 395] 23 _pc4d.don: PnP CCO ipv4 discovery not successful
[06/27/23 13:12:33.182 UTC 57A 395] 31.5 _pdm.inf: no ipv6 idb, skipping PnP CCO ipv6 Discovery
[06/27/23 13:12:33.182 UTC 57B 395] Info: PnP profile configuration was unsuccessful
[06/27/23 13:12:33.182 UTC 57C 395] CLEAN UP VRF
[06/27/23 13:12:33.182 UTC 57D 395] 31 _pdcr.def: PnP discovery failed on 9
[06/27/23 13:12:43.183 UTC 57E 395] 37 _pisce.wAr.moe: nvram:/startup-config missing or empty
[06/27/23 13:12:43.183 UTC 57F 395] Platform discovery not required
[06/27/23 13:12:43.183 UTC 580 395] 1 spd.drc: PnP Discovery trial number[32]
[06/27/23 13:12:43.183 UTC 581 395] 1 spd.idm: Initiating PnP discovery manager
[06/27/23 13:12:43.183 UTC 582 395] Info: PNP discovery reqd - DHCP Reqd:1
[06/27/23 13:12:43.186 UTC 583 395] 24 _pddio.err.pro: no op43 discovered
[06/27/23 13:12:43.186 UTC 584 395] cant discover via dhcp ipv4 op43
[06/27/23 13:12:43.186 UTC 585 395] 24 _pdh4d.wAr.fin: PnP DHCP ipv4 discovery not successful
[06/27/23 13:12:45.187 UTC 586 395] 32.1 _pdm.inf: no ipv6 idb, skipping PnP DHCP ipv6 Discovery
[06/27/23 13:12:45.187 UTC 587 395] 24 _pd4d.info: Starting PnP DNS ipv4 discovery
[06/27/23 13:12:45.187 UTC 588 395] CLEAN UP VRF
[06/27/23 13:12:45.187 UTC 589 395] 24 _pddd.info: Domain Name [-] on Interface [Vlan111]
[06/27/23 13:12:45.187 UTC 58A 395] CLEAN UP VRF
[06/27/23 13:12:45.187 UTC 58B 395] 24 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/1]
[06/27/23 13:12:45.187 UTC 58C 395] CLEAN UP VRF
[06/27/23 13:12:45.187 UTC 58D 395] 24 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/3]
[06/27/23 13:12:45.187 UTC 58E 395] CLEAN UP VRF
[06/27/23 13:12:45.187 UTC 58F 395] 24 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/4]
[06/27/23 13:12:45.187 UTC 590 395] CLEAN UP VRF
[06/27/23 13:12:45.187 UTC 591 395] 24 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/5]
[06/27/23 13:12:45.187 UTC 592 395] CLEAN UP VRF
[06/27/23 13:12:45.187 UTC 593 395] 24 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/6]
[06/27/23 13:12:45.187 UTC 594 395] CLEAN UP VRF
[06/27/23 13:12:45.187 UTC 595 395] 24 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/7]
[06/27/23 13:12:45.187 UTC 596 395] CLEAN UP VRF
[06/27/23 13:12:45.187 UTC 597 395] 24 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/9]
[06/27/23 13:12:45.187 UTC 598 395] CLEAN UP VRF
[06/27/23 13:12:45.187 UTC 599 395] 24 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/10]
[06/27/23 13:12:45.187 UTC 59A 395] CLEAN UP VRF
[06/27/23 13:12:45.187 UTC 59B 395] 24 _pddd.info: Domain Name [-] on Interface [GigabitEthernet2/0/1]
[06/27/23 13:12:45.188 UTC 59C 395] CLEAN UP VRF
[06/27/23 13:12:45.188 UTC 59D 395] 24 _pddd.info: Domain Name [-] on Interface [TenGigabitEthernet2/1/1]
[06/27/23 13:12:45.188 UTC 59E 395] 24 _pddd.wAr.dna: cant obtain good domain name from any interface
[06/27/23 13:12:45.188 UTC 59F 395] 24 _pd4d.wAr.fin: PnP DNS ipv4 discovery not successful
[06/27/23 13:12:47.186 UTC 5A0 395] 32.3 _pdm.inf: no ipv6 idb, skipping PnP DNS ipv6 Discovery
[06/27/23 13:12:47.186 UTC 5A1 395] CLEAN UP VRF
[06/27/23 13:12:47.186 UTC 5A2 395] 24 _pc4d.info: Try without VRF for CCO ipv4 discovery
[06/27/23 13:12:47.186 UTC 5A3 395] 24 _pc4d.info: Starting PnP CCO ipv4 discovery
[06/27/23 13:12:47.186 UTC 5A4 395] 25 _pcdd.ciw: Check if CCO is waiting
[06/27/23 13:12:47.186 UTC 5A5 395] 24 _picw.don: NO CCO wait process exists.
[06/27/23 13:12:47.186 UTC 5A6 395] PNP-CCO-WAIT (24): Name=[PNPA_CCO_WAIT], OK-To-Run=Yes, Wait=0, Last-Wait=0 se        c
        PID=-1, Last-PID=-1, Created:(T=0/S=0/F=0<truncated>
[06/27/23 13:12:47.186 UTC 5A7 395] 25 _pcdd.orc: CCO is NOT waiting. Trying CCO discovery
[06/27/23 13:12:51.958 UTC 5A8 208] CDP Native vlan on TenGigabitEthernet2/1/1 = 999 found=1 last=999
[06/27/23 13:12:51.958 UTC 5A9 208] CDP Native vlan on TenGigabitEthernet2/1/1 = 999 found=1 last=999
[06/27/23 13:12:55.193 UTC 5AA 395] 24 _pcraci.wAr.psr: pnp_server not resolved
[06/27/23 13:12:55.193 UTC 5AB 395] 25 _pcdd.eRr.rai: Hostname resolution failed
[06/27/23 13:12:55.193 UTC 5AC 395] 24 _pc4d.don: PnP CCO ipv4 discovery not successful
[06/27/23 13:12:57.190 UTC 5AD 395] 32.5 _pdm.inf: no ipv6 idb, skipping PnP CCO ipv6 Discovery
[06/27/23 13:12:57.190 UTC 5AE 395] Info: PnP profile configuration was unsuccessful
[06/27/23 13:12:57.190 UTC 5AF 395] CLEAN UP VRF
[06/27/23 13:12:57.190 UTC 5B0 395] 32 _pdcr.def: PnP discovery failed on 9
[06/27/23 13:13:00.530 UTC 5B1 428] 1 _pnas.info: ip resolved by auto-install
[06/27/23 13:13:00.530 UTC 5B2 428] 1 _rpwd: PnP Webui config reverted (4)
[06/27/23 13:13:07.190 UTC 5B3 395] 38 _pisce.wAr.moe: nvram:/startup-config missing or empty
[06/27/23 13:13:07.190 UTC 5B4 395] Platform discovery not required
[06/27/23 13:13:07.190 UTC 5B5 395] 1 spd.drc: PnP Discovery trial number[33]
[06/27/23 13:13:07.190 UTC 5B6 395] 1 spd.idm: Initiating PnP discovery manager
[06/27/23 13:13:07.190 UTC 5B7 395] Info: PNP discovery reqd - DHCP Reqd:1
[06/27/23 13:13:07.195 UTC 5B8 395] 25 _pddio.err.pro: no op43 discovered
[06/27/23 13:13:07.195 UTC 5B9 395] cant discover via dhcp ipv4 op43
[06/27/23 13:13:07.195 UTC 5BA 395] 25 _pdh4d.wAr.fin: PnP DHCP ipv4 discovery not successful
[06/27/23 13:13:09.195 UTC 5BB 395] 33.1 _pdm.inf: no ipv6 idb, skipping PnP DHCP ipv6 Discovery
[06/27/23 13:13:09.195 UTC 5BC 395] 25 _pd4d.info: Starting PnP DNS ipv4 discovery
[06/27/23 13:13:09.195 UTC 5BD 395] CLEAN UP VRF
[06/27/23 13:13:09.195 UTC 5BE 395] 25 _pddd.info: Domain Name [-] on Interface [Vlan111]
[06/27/23 13:13:09.195 UTC 5BF 395] CLEAN UP VRF
[06/27/23 13:13:09.195 UTC 5C0 395] 25 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/1]
[06/27/23 13:13:09.195 UTC 5C1 395] CLEAN UP VRF
[06/27/23 13:13:09.195 UTC 5C2 395] 25 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/3]
[06/27/23 13:13:09.195 UTC 5C3 395] CLEAN UP VRF
[06/27/23 13:13:09.195 UTC 5C4 395] 25 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/4]
[06/27/23 13:13:09.195 UTC 5C5 395] CLEAN UP VRF
[06/27/23 13:13:09.195 UTC 5C6 395] 25 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/5]
[06/27/23 13:13:09.195 UTC 5C7 395] CLEAN UP VRF
[06/27/23 13:13:09.196 UTC 5C8 395] 25 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/6]
[06/27/23 13:13:09.196 UTC 5C9 395] CLEAN UP VRF
[06/27/23 13:13:09.196 UTC 5CA 395] 25 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/7]
[06/27/23 13:13:09.196 UTC 5CB 395] CLEAN UP VRF
[06/27/23 13:13:09.196 UTC 5CC 395] 25 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/9]
[06/27/23 13:13:09.196 UTC 5CD 395] CLEAN UP VRF
[06/27/23 13:13:09.196 UTC 5CE 395] 25 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/10]
[06/27/23 13:13:09.196 UTC 5CF 395] CLEAN UP VRF
[06/27/23 13:13:09.196 UTC 5D0 395] 25 _pddd.info: Domain Name [-] on Interface [GigabitEthernet2/0/1]
[06/27/23 13:13:09.196 UTC 5D1 395] CLEAN UP VRF
[06/27/23 13:13:09.196 UTC 5D2 395] 25 _pddd.info: Domain Name [-] on Interface [TenGigabitEthernet2/1/1]
[06/27/23 13:13:09.196 UTC 5D3 395] 25 _pddd.wAr.dna: cant obtain good domain name from any interface
[06/27/23 13:13:09.196 UTC 5D4 395] 25 _pd4d.wAr.fin: PnP DNS ipv4 discovery not successful
[06/27/23 13:13:11.194 UTC 5D5 395] 33.3 _pdm.inf: no ipv6 idb, skipping PnP DNS ipv6 Discovery
[06/27/23 13:13:11.194 UTC 5D6 395] CLEAN UP VRF
[06/27/23 13:13:11.194 UTC 5D7 395] 25 _pc4d.info: Try without VRF for CCO ipv4 discovery
[06/27/23 13:13:11.194 UTC 5D8 395] 25 _pc4d.info: Starting PnP CCO ipv4 discovery
[06/27/23 13:13:11.194 UTC 5D9 395] 26 _pcdd.ciw: Check if CCO is waiting
[06/27/23 13:13:11.194 UTC 5DA 395] 25 _picw.don: NO CCO wait process exists.
[06/27/23 13:13:11.194 UTC 5DB 395] PNP-CCO-WAIT (25): Name=[PNPA_CCO_WAIT], OK-To-Run=Yes, Wait=0, Last-Wait=0 sec
[06/27/23 13:13:11.194 UTC 5DC 395] 26 _pcdd.orc: CCO is NOT waiting. Trying CCO discovery
[06/27/23 13:13:19.200 UTC 5DD 395] 25 _pcraci.wAr.psr: pnp_server not resolved
[06/27/23 13:13:19.200 UTC 5DE 395] 26 _pcdd.eRr.rai: Hostname resolution failed
[06/27/23 13:13:19.200 UTC 5DF 395] 25 _pc4d.don: PnP CCO ipv4 discovery not successful
[06/27/23 13:13:21.199 UTC 5E0 395] 33.5 _pdm.inf: no ipv6 idb, skipping PnP CCO ipv6 Discovery
[06/27/23 13:13:21.199 UTC 5E1 395] Info: PnP profile configuration was unsuccessful
[06/27/23 13:13:21.199 UTC 5E2 395] CLEAN UP VRF
[06/27/23 13:13:21.199 UTC 5E3 395] 33 _pdcr.def: PnP discovery failed on 9
[06/27/23 13:13:31.199 UTC 5E4 395] 39 _pisce.wAr.moe: nvram:/startup-config missing or empty
[06/27/23 13:13:31.199 UTC 5E5 395] Platform discovery not required
[06/27/23 13:13:31.199 UTC 5E6 395] 1 spd.drc: PnP Discovery trial number[34]
[06/27/23 13:13:31.199 UTC 5E7 395] 1 spd.idm: Initiating PnP discovery manager
[06/27/23 13:13:31.199 UTC 5E8 395] Info: PNP discovery reqd - DHCP Reqd:1
[06/27/23 13:13:31.204 UTC 5E9 395] 26 _pddio.err.pro: no op43 discovered
[06/27/23 13:13:31.204 UTC 5EA 395] cant discover via dhcp ipv4 op43
[06/27/23 13:13:31.204 UTC 5EB 395] 26 _pdh4d.wAr.fin: PnP DHCP ipv4 discovery not successful
[06/27/23 13:13:33.203 UTC 5EC 395] 34.1 _pdm.inf: no ipv6 idb, skipping PnP DHCP ipv6 Discovery
[06/27/23 13:13:33.203 UTC 5ED 395] 26 _pd4d.info: Starting PnP DNS ipv4 discovery
[06/27/23 13:13:33.203 UTC 5EE 395] CLEAN UP VRF
[06/27/23 13:13:33.203 UTC 5EF 395] 26 _pddd.info: Domain Name [-] on Interface [Vlan111]
[06/27/23 13:13:33.203 UTC 5F0 395] CLEAN UP VRF
[06/27/23 13:13:33.203 UTC 5F1 395] 26 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/1]
[06/27/23 13:13:33.203 UTC 5F2 395] CLEAN UP VRF
[06/27/23 13:13:33.203 UTC 5F3 395] 26 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/3]
[06/27/23 13:13:33.203 UTC 5F4 395] CLEAN UP VRF
[06/27/23 13:13:33.203 UTC 5F5 395] 26 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/4]
[06/27/23 13:13:33.203 UTC 5F6 395] CLEAN UP VRF
[06/27/23 13:13:33.203 UTC 5F7 395] 26 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/5]
[06/27/23 13:13:33.203 UTC 5F8 395] CLEAN UP VRF
[06/27/23 13:13:33.203 UTC 5F9 395] 26 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/6]
[06/27/23 13:13:33.203 UTC 5FA 395] CLEAN UP VRF
[06/27/23 13:13:33.203 UTC 5FB 395] 26 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/7]
[06/27/23 13:13:33.203 UTC 5FC 395] CLEAN UP VRF
[06/27/23 13:13:33.203 UTC 5FD 395] 26 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/9]
[06/27/23 13:13:33.203 UTC 5FE 395] CLEAN UP VRF
[06/27/23 13:13:33.203 UTC 5FF 395] 26 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/10]
[06/27/23 13:13:33.204 UTC 600 395] CLEAN UP VRF
[06/27/23 13:13:33.204 UTC 601 395] 26 _pddd.info: Domain Name [-] on Interface [GigabitEthernet2/0/1]
[06/27/23 13:13:33.204 UTC 602 395] CLEAN UP VRF
[06/27/23 13:13:33.204 UTC 603 395] 26 _pddd.info: Domain Name [-] on Interface [TenGigabitEthernet2/1/1]
[06/27/23 13:13:33.204 UTC 604 395] 26 _pddd.wAr.dna: cant obtain good domain name from any interface
[06/27/23 13:13:33.204 UTC 605 395] 26 _pd4d.wAr.fin: PnP DNS ipv4 discovery not successful
[06/27/23 13:13:35.202 UTC 606 395] 34.3 _pdm.inf: no ipv6 idb, skipping PnP DNS ipv6 Discovery
[06/27/23 13:13:35.202 UTC 607 395] CLEAN UP VRF
[06/27/23 13:13:35.202 UTC 608 395] 26 _pc4d.info: Try without VRF for CCO ipv4 discovery
[06/27/23 13:13:35.202 UTC 609 395] 26 _pc4d.info: Starting PnP CCO ipv4 discovery
[06/27/23 13:13:35.202 UTC 60A 395] 27 _pcdd.ciw: Check if CCO is waiting
[06/27/23 13:13:35.202 UTC 60B 395] 26 _picw.don: NO CCO wait process exists.
[06/27/23 13:13:35.202 UTC 60C 395] PNP-CCO-WAIT (26): Name=[PNPA_CCO_WAIT], OK-To-Run=Yes, Wait=0, Last-Wait=0 sec
[06/27/23 13:13:35.202 UTC 60D 395] 27 _pcdd.orc: CCO is NOT waiting. Trying CCO discovery
[06/27/23 13:13:44.207 UTC 60E 395] 26 _pcraci.wAr.psr: pnp_server not resolved
[06/27/23 13:13:44.207 UTC 60F 395] 27 _pcdd.eRr.rai: Hostname resolution failed
[06/27/23 13:13:44.207 UTC 610 395] 26 _pc4d.don: PnP CCO ipv4 discovery not successful
[06/27/23 13:13:46.207 UTC 611 395] 34.5 _pdm.inf: no ipv6 idb, skipping PnP CCO ipv6 Discovery
[06/27/23 13:13:46.207 UTC 612 395] Info: PnP profile configuration was unsuccessful
[06/27/23 13:13:46.207 UTC 613 395] CLEAN UP VRF
[06/27/23 13:13:46.207 UTC 614 395] 34 _pdcr.def: PnP discovery failed on 9
[06/27/23 13:13:46.477 UTC 615 208] CDP Native vlan on TenGigabitEthernet2/1/1 = 999 found=1 last=999
[06/27/23 13:13:46.477 UTC 616 208] CDP Native vlan on TenGigabitEthernet2/1/1 = 999 found=1 last=999
[06/27/23 13:13:56.208 UTC 617 395] 40 _pisce.wAr.moe: nvram:/startup-config missing or empty
[06/27/23 13:13:56.208 UTC 618 395] Platform discovery not required
[06/27/23 13:13:56.208 UTC 619 395] 1 spd.drc: PnP Discovery trial number[35]
[06/27/23 13:13:56.208 UTC 61A 395] 1 spd.idm: Initiating PnP discovery manager
[06/27/23 13:13:56.208 UTC 61B 395] Info: PNP discovery reqd - DHCP Reqd:1
[06/27/23 13:13:56.212 UTC 61C 395] 27 _pddio.err.pro: no op43 discovered
[06/27/23 13:13:56.212 UTC 61D 395] cant discover via dhcp ipv4 op43
[06/27/23 13:13:56.212 UTC 61E 395] 27 _pdh4d.wAr.fin: PnP DHCP ipv4 discovery not successful
[06/27/23 13:13:58.210 UTC 61F 395] 35.1 _pdm.inf: no ipv6 idb, skipping PnP DHCP ipv6 Discovery
[06/27/23 13:13:58.210 UTC 620 395] 27 _pd4d.info: Starting PnP DNS ipv4 discovery
[06/27/23 13:13:58.210 UTC 621 395] CLEAN UP VRF
[06/27/23 13:13:58.210 UTC 622 395] 27 _pddd.info: Domain Name [-] on Interface [Vlan111]
[06/27/23 13:13:58.210 UTC 623 395] CLEAN UP VRF
[06/27/23 13:13:58.210 UTC 624 395] 27 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/1]
[06/27/23 13:13:58.210 UTC 625 395] CLEAN UP VRF
[06/27/23 13:13:58.210 UTC 626 395] 27 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/3]
[06/27/23 13:13:58.210 UTC 627 395] CLEAN UP VRF
[06/27/23 13:13:58.210 UTC 628 395] 27 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/4]
[06/27/23 13:13:58.210 UTC 629 395] CLEAN UP VRF
[06/27/23 13:13:58.210 UTC 62A 395] 27 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/5]
[06/27/23 13:13:58.210 UTC 62B 395] CLEAN UP VRF
[06/27/23 13:13:58.210 UTC 62C 395] 27 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/6]
[06/27/23 13:13:58.210 UTC 62D 395] CLEAN UP VRF
[06/27/23 13:13:58.210 UTC 62E 395] 27 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/7]
[06/27/23 13:13:58.210 UTC 62F 395] CLEAN UP VRF
[06/27/23 13:13:58.210 UTC 630 395] 27 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/9]
[06/27/23 13:13:58.210 UTC 631 395] CLEAN UP VRF
[06/27/23 13:13:58.210 UTC 632 395] 27 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/10]
[06/27/23 13:13:58.210 UTC 633 395] CLEAN UP VRF
[06/27/23 13:13:58.211 UTC 634 395] 27 _pddd.info: Domain Name [-] on Interface [GigabitEthernet2/0/1]
[06/27/23 13:13:58.211 UTC 635 395] CLEAN UP VRF
[06/27/23 13:13:58.211 UTC 636 395] 27 _pddd.info: Domain Name [-] on Interface [TenGigabitEthernet2/1/1]
[06/27/23 13:13:58.211 UTC 637 395] 27 _pddd.wAr.dna: cant obtain good domain name from any interface
[06/27/23 13:13:58.211 UTC 638 395] 27 _pd4d.wAr.fin: PnP DNS ipv4 discovery not successful
[06/27/23 13:14:00.211 UTC 639 395] 35.3 _pdm.inf: no ipv6 idb, skipping PnP DNS ipv6 Discovery
[06/27/23 13:14:00.211 UTC 63A 395] CLEAN UP VRF
[06/27/23 13:14:00.211 UTC 63B 395] 27 _pc4d.info: Try without VRF for CCO ipv4 discovery
[06/27/23 13:14:00.211 UTC 63C 395] 27 _pc4d.info: Starting PnP CCO ipv4 discovery
[06/27/23 13:14:00.211 UTC 63D 395] 28 _pcdd.ciw: Check if CCO is waiting
[06/27/23 13:14:00.211 UTC 63E 395] 27 _picw.don: NO CCO wait process exists.
[06/27/23 13:14:00.211 UTC 63F 395] PNP-CCO-WAIT (27): Name=[PNPA_CCO_WAIT], OK-To-Run=Yes, Wait=0, Last-Wait=0 sec
[06/27/23 13:14:00.211 UTC 640 395] 28 _pcdd.orc: CCO is NOT waiting. Trying CCO discovery
[06/27/23 13:14:08.216 UTC 641 395] 27 _pcraci.wAr.psr: pnp_server not resolved
[06/27/23 13:14:08.216 UTC 642 395] 28 _pcdd.eRr.rai: Hostname resolution failed
[06/27/23 13:14:08.216 UTC 643 395] 27 _pc4d.don: PnP CCO ipv4 discovery not successful
[06/27/23 13:14:10.214 UTC 644 395] 35.5 _pdm.inf: no ipv6 idb, skipping PnP CCO ipv6 Discovery
[06/27/23 13:14:10.214 UTC 645 395] Info: PnP profile configuration was unsuccessful
[06/27/23 13:14:10.214 UTC 646 395] CLEAN UP VRF
[06/27/23 13:14:10.214 UTC 647 395] 35 _pdcr.def: PnP discovery failed on 9
[06/27/23 13:14:20.214 UTC 648 395] 41 _pisce.wAr.moe: nvram:/startup-config missing or empty
[06/27/23 13:14:20.214 UTC 649 395] Platform discovery not required
[06/27/23 13:14:20.214 UTC 64A 395] 1 spd.drc: PnP Discovery trial number[36]
[06/27/23 13:14:20.214 UTC 64B 395] 1 spd.idm: Initiating PnP discovery manager
[06/27/23 13:14:20.214 UTC 64C 395] Info: PNP discovery reqd - DHCP Reqd:1
[06/27/23 13:14:20.219 UTC 64D 395] 28 _pddio.err.pro: no op43 discovered
[06/27/23 13:14:20.219 UTC 64E 395] cant discover via dhcp ipv4 op43
[06/27/23 13:14:20.219 UTC 64F 395] 28 _pdh4d.wAr.fin: PnP DHCP ipv4 discovery not successful
[06/27/23 13:14:22.218 UTC 650 395] 36.1 _pdm.inf: no ipv6 idb, skipping PnP DHCP ipv6 Discovery
[06/27/23 13:14:22.218 UTC 651 395] 28 _pd4d.info: Starting PnP DNS ipv4 discovery
[06/27/23 13:14:22.218 UTC 652 395] CLEAN UP VRF
[06/27/23 13:14:22.218 UTC 653 395] 28 _pddd.info: Domain Name [-] on Interface [Vlan111]
[06/27/23 13:14:22.218 UTC 654 395] CLEAN UP VRF
[06/27/23 13:14:22.218 UTC 655 395] 28 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/1]
[06/27/23 13:14:22.218 UTC 656 395] CLEAN UP VRF
[06/27/23 13:14:22.218 UTC 657 395] 28 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/3]
[06/27/23 13:14:22.218 UTC 658 395] CLEAN UP VRF
[06/27/23 13:14:22.218 UTC 659 395] 28 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/4]
[06/27/23 13:14:22.218 UTC 65A 395] CLEAN UP VRF
[06/27/23 13:14:22.218 UTC 65B 395] 28 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/5]
[06/27/23 13:14:22.218 UTC 65C 395] CLEAN UP VRF
[06/27/23 13:14:22.218 UTC 65D 395] 28 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/6]
[06/27/23 13:14:22.218 UTC 65E 395] CLEAN UP VRF
[06/27/23 13:14:22.218 UTC 65F 395] 28 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/7]
[06/27/23 13:14:22.218 UTC 660 395] CLEAN UP VRF
[06/27/23 13:14:22.218 UTC 661 395] 28 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/9]
[06/27/23 13:14:22.218 UTC 662 395] CLEAN UP VRF
[06/27/23 13:14:22.218 UTC 663 395] 28 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/10]
[06/27/23 13:14:22.219 UTC 664 395] CLEAN UP VRF
[06/27/23 13:14:22.219 UTC 665 395] 28 _pddd.info: Domain Name [-] on Interface [GigabitEthernet2/0/1]
[06/27/23 13:14:22.219 UTC 666 395] CLEAN UP VRF
[06/27/23 13:14:22.219 UTC 667 395] 28 _pddd.info: Domain Name [-] on Interface [TenGigabitEthernet2/1/1]
[06/27/23 13:14:22.219 UTC 668 395] 28 _pddd.wAr.dna: cant obtain good domain name from any interface
[06/27/23 13:14:22.219 UTC 669 395] 28 _pd4d.wAr.fin: PnP DNS ipv4 discovery not successful
[06/27/23 13:14:24.218 UTC 66A 395] 36.3 _pdm.inf: no ipv6 idb, skipping PnP DNS ipv6 Discovery
[06/27/23 13:14:24.218 UTC 66B 395] CLEAN UP VRF
[06/27/23 13:14:24.218 UTC 66C 395] 28 _pc4d.info: Try without VRF for CCO ipv4 discovery
[06/27/23 13:14:24.218 UTC 66D 395] 28 _pc4d.info: Starting PnP CCO ipv4 discovery
[06/27/23 13:14:24.218 UTC 66E 395] 29 _pcdd.ciw: Check if CCO is waiting
[06/27/23 13:14:24.218 UTC 66F 395] 28 _picw.don: NO CCO wait process exists.
[06/27/23 13:14:24.218 UTC 670 395] PNP-CCO-WAIT (28): Name=[PNPA_CCO_WAIT], OK-To-Run=Yes, Wait=0, Last-Wait=0 sec
[06/27/23 13:14:24.218 UTC 671 395] 29 _pcdd.orc: CCO is NOT waiting. Trying CCO discovery
[06/27/23 13:14:32.224 UTC 672 395] 28 _pcraci.wAr.psr: pnp_server not resolved
[06/27/23 13:14:32.224 UTC 673 395] 29 _pcdd.eRr.rai: Hostname resolution failed
[06/27/23 13:14:32.224 UTC 674 395] 28 _pc4d.don: PnP CCO ipv4 discovery not successful
[06/27/23 13:14:34.222 UTC 675 395] 36.5 _pdm.inf: no ipv6 idb, skipping PnP CCO ipv6 Discovery
[06/27/23 13:14:34.222 UTC 676 395] Info: PnP profile configuration was unsuccessful
[06/27/23 13:14:34.222 UTC 677 395] CLEAN UP VRF
[06/27/23 13:14:34.222 UTC 678 395] 36 _pdcr.def: PnP discovery failed on 9
[06/27/23 13:14:41.997 UTC 679 208] CDP Native vlan on TenGigabitEthernet2/1/1 = 999 found=1 last=999
[06/27/23 13:14:41.997 UTC 67A 208] CDP Native vlan on TenGigabitEthernet2/1/1 = 999 found=1 last=999
[06/27/23 13:14:44.223 UTC 67B 395] 42 _pisce.wAr.moe: nvram:/startup-config missing or empty
[06/27/23 13:14:44.223 UTC 67C 395] Platform discovery not required
[06/27/23 13:14:44.223 UTC 67D 395] 1 spd.drc: PnP Discovery trial number[37]
[06/27/23 13:14:44.223 UTC 67E 395] 1 spd.idm: Initiating PnP discovery manager
[06/27/23 13:14:44.223 UTC 67F 395] Info: PNP discovery reqd - DHCP Reqd:1
[06/27/23 13:14:44.227 UTC 680 395] 29 _pddio.err.pro: no op43 discovered
[06/27/23 13:14:44.227 UTC 681 395] cant discover via dhcp ipv4 op43
[06/27/23 13:14:44.228 UTC 682 395] 29 _pdh4d.wAr.fin: PnP DHCP ipv4 discovery not successful
[06/27/23 13:14:46.226 UTC 683 395] 37.1 _pdm.inf: no ipv6 idb, skipping PnP DHCP ipv6 Discovery
[06/27/23 13:14:46.226 UTC 684 395] 29 _pd4d.info: Starting PnP DNS ipv4 discovery
[06/27/23 13:14:46.226 UTC 685 395] CLEAN UP VRF
[06/27/23 13:14:46.226 UTC 686 395] 29 _pddd.info: Domain Name [-] on Interface [Vlan111]
[06/27/23 13:14:46.226 UTC 687 395] CLEAN UP VRF
[06/27/23 13:14:46.226 UTC 688 395] 29 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/1]
[06/27/23 13:14:46.226 UTC 689 395] CLEAN UP VRF
[06/27/23 13:14:46.226 UTC 68A 395] 29 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/3]
[06/27/23 13:14:46.226 UTC 68B 395] CLEAN UP VRF
[06/27/23 13:14:46.226 UTC 68C 395] 29 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/4]
[06/27/23 13:14:46.226 UTC 68D 395] CLEAN UP VRF
[06/27/23 13:14:46.226 UTC 68E 395] 29 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/5]
[06/27/23 13:14:46.226 UTC 68F 395] CLEAN UP VRF
[06/27/23 13:14:46.226 UTC 690 395] 29 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/6]
[06/27/23 13:14:46.226 UTC 691 395] CLEAN UP VRF
[06/27/23 13:14:46.226 UTC 692 395] 29 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/7]
[06/27/23 13:14:46.226 UTC 693 395] CLEAN UP VRF
[06/27/23 13:14:46.226 UTC 694 395] 29 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/9]
[06/27/23 13:14:46.226 UTC 695 395] CLEAN UP VRF
[06/27/23 13:14:46.226 UTC 696 395] 29 _pddd.info: Domain Name [-] on Interface [GigabitEthernet1/0/10]
[06/27/23 13:14:46.226 UTC 697 395] CLEAN UP VRF
[06/27/23 13:14:46.226 UTC 698 395] 29 _pddd.info: Domain Name [-] on Interface [GigabitEthernet2/0/1]
[06/27/23 13:14:46.226 UTC 699 395] CLEAN UP VRF
[06/27/23 13:14:46.226 UTC 69A 395] 29 _pddd.info: Domain Name [-] on Interface [TenGigabitEthernet2/1/1]
[06/27/23 13:14:46.226 UTC 69B 395] 29 _pddd.wAr.dna: cant obtain good domain name from any interface
[06/27/23 13:14:46.227 UTC 69C 395] 29 _pd4d.wAr.fin: PnP DNS ipv4 discovery not successful
[06/27/23 13:14:48.226 UTC 69D 395] 37.3 _pdm.inf: no ipv6 idb, skipping PnP DNS ipv6 Discovery
[06/27/23 13:14:48.226 UTC 69E 395] CLEAN UP VRF
[06/27/23 13:14:48.226 UTC 69F 395] 29 _pc4d.info: Try without VRF for CCO ipv4 discovery
[06/27/23 13:14:48.226 UTC 6A0 395] 29 _pc4d.info: Starting PnP CCO ipv4 discovery
[06/27/23 13:14:48.226 UTC 6A1 395] 30 _pcdd.ciw: Check if CCO is waiting
[06/27/23 13:14:48.226 UTC 6A2 395] 29 _picw.don: NO CCO wait process exists.
[06/27/23 13:14:48.226 UTC 6A3 395] PNP-CCO-WAIT (29): Name=[PNPA_CCO_WAIT], OK-To-Run=Yes, Wait=0, Last-Wait=0 sec
[06/27/23 13:14:48.226 UTC 6A4 395] 30 _pcdd.orc: CCO is NOT waiting. Trying CCO discovery
[06/27/23 13:14:57.235 UTC 6A5 395] 29 _pcraci.wAr.psr: pnp_server not resolved
[06/27/23 13:14:57.235 UTC 6A6 395] 30 _pcdd.eRr.rai: Hostname resolution failed
[06/27/23 13:14:57.235 UTC 6A7 395] 29 _pc4d.don: PnP CCO ipv4 discovery not successful
[06/27/23 13:14:59.234 UTC 6A8 395] 37.5 _pdm.inf: no ipv6 idb, skipping PnP CCO ipv6 Discovery
[06/27/23 13:14:59.234 UTC 6A9 395] Info: PnP profile configuration was unsuccessful
[06/27/23 13:14:59.234 UTC 6AA 395] CLEAN UP VRF
[06/27/23 13:14:59.234 UTC 6AB 395] 37 _pdcr.def: PnP discovery failed on 9
[06/27/23 13:15:09.234 UTC 6AC 395] 43 _pisce.wAr.moe: nvram:/startup-config missing or empty
[06/27/23 13:15:09.234 UTC 6AD 395] Platform discovery not required
[06/27/23 13:15:09.234 UTC 6AE 395] 1 spd.drc: PnP Discovery trial number[38]
[06/27/23 13:15:09.234 UTC 6AF 395] 1 spd.idm: Initiating PnP discovery manager
[06/27/23 13:15:09.234 UTC 6B0 395] Info: PNP discovery reqd - DHCP Reqd:1
[06/27/23 13:15:09.237 UTC 6B1 395] 30 _pddio.err.pro: no op43 discovered
[06/27/23 13:15:09.237 UTC 6B2 395] cant discover via dhcp ipv4 op43
[06/27/23 13:15:09.237 UTC 6B3 395] 30 _pdh4d.wAr.fin: PnP DHCP ipv4 discovery not successful
There might be some problem is DHCP option 43.  Who is providing the DHCP and how option 43 is being handled ?
pholos
This is my dhcp config, it's on the Core switch.
ip dhcp pool DNA
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 43 ascii "5A1N;B2;K4;I10.143.177.251;J80;"
pholos
My bad
