Showing results forĀ
Search instead forĀ
Did you mean:Ā
Firewall need to be placed in SDACCess solution
AjayKumar30
we are implementing SDaccess solution for our client, after all network device and configuration done from network side , client demanding for need to place firewall as well
, from network side i recommended firewall would place between router and fusion , but firewall guy does not agree they advise we have placed the firewall between fusion and border switch,
not sure which is correct, we also make sure latency between dnac and ise and dnac to edge switch and wlc have to be less. please advise what issue exactly facing if we place the firewall between fusion and border node, what right place for firewall, I am also attaching the diagram,
balaji.bandi
Is this FW for Perimeter side  traffic going out to internet and coming in ?
always Place the Firewall outside SD-Access network - that can between router Router and fusion as your diagram shows.
check also design guide :
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/Campus/cisco-sda-design-guide.html
BB
balaji.bandi
BB
