How to check DNAc is hardware or VM, it is cluster or not on gui
palani2010
You can check if DNAC is hw or vm by going from the hamburger menu > System > System 360 > Service Explorer. Here hover with your mouse pointer over the DNAC cluster and you will see the serial number and product ID. A hardware DNAC is for example indicated by a product ID like DN2-HW-APL-U.
You can verify also using the serial number and Device coverage site https://cway.cisco.com/sncheck/ in which you input the serial number and you get more details about your product.
For the cluster verification, go from the hamburger menu > System > Settings > System Configuration > High Availability where you can find info about your DNAC installation clustering configuration.
Regards, LG
*** Please Rate All Helpful Responses ***
Regards, LG
