How to get notified if DNAC does not receive telemetry data from WLC?
Dominic Stalder
Hi guys
I tried to find a way to get notified, as soon as our Cisco DNAC 2.3.5.3 does not receive any telemetry / assurance data from our Cisco WLCs.
I asked ChatGPT and got this answer, but was not able to find the menus specified in the given answer:
  1. Log in to your Cisco DNA Center web interface using a web browser.
  2. Navigate to the "Assurance" tab in the main menu.
  3. In the left-hand menu, select "Alarms & Events" and then click on "Alarms."
  4. Click on the "Create Alarm" button to start creating a new alarm.
  5. In the "Alarm Name" field, enter a descriptive name for the alarm, such as "No Telemetry Data from WLC."
  6. In the "Conditions" section, click on the "Add" button to define the condition for the alarm.
  7. From the dropdown menu, select "Device" as the type of condition.
  8. Specify the criteria for the condition. For example, you can select "Device Family" and choose "Wireless LAN Controller" from the dropdown menu.
  9. Scroll down to the "Fault" section and click on the "Add" button to add a fault condition.
  10. Select "Telemetry Data Availability" as the type of fault condition.
  11. In the subsequent dropdown menu, choose "Not Received" as the condition.
  12. In the "Severity" section, select the appropriate severity level for the alarm, such as "Critical" or "Major."
  13. Optionally, you can configure other parameters such as the alarm description, additional conditions, and suppression settings based on your requirements.
  14. Once you have configured the alarm settings, click on the "Save" button to save the alarm.
Does anybody know, where I can find and specify a Cisco DNAC assurance alarm in DNAC 2.3.5?
Thanks in advance and best regards
Dominic
Preston Chilcote
Platform->Developer Toolkit->Event Notifications.  Click the Create New card and follow the workflow.  The Event to search for is "WLC Monitor."
Preston Chilcote
Hi Preston
thanks for your helpful hint, I finally found the event notifications and configured one for "WLC Monitor".
Can you maybe explain, what events are correlated under "WLC monitor"?
Thanks and best regards
Dominic
