10-11-2023 05:59 PM
We are moving from SNMPv2c to SNMPv3 wherever we can ... rolling out the SNMPv3 credentials from DNAC is super-easy, but how do you get DNAC to remove the old SNMPv2c credentials/settings?
10-23-2023 11:52 AM
You can create a configuration template with the needed "no snmp" commands.
https://blogs.cisco.com/networking/dnactemplatesdayn-pt4
11-15-2023 03:08 PM
Yay, DNAC templates. <said with sarcasm>
I was hoping for something simpler than DNAC templates - my experience with them so far is not good - but I suppose I'll need to get adept at using them sometime .. I suppose something relatively small and simple as removing old/unwanted credentials is a good starting point.
Thanks for your help.
