09-08-2023 01:38 PM
My DNA Center is currently on version 2.2.2.8. When I go to "System" I don't have the option for "Software Updates" as seen in the image. Anyone knows why the software update option is missing?
09-08-2023 02:15 PM
Do you have a cloud icon in the upper right corner? That's the shortcut I usually use.
09-11-2023 04:52 AM
I don't have a cloud icon in the upper right.
09-11-2023 07:14 AM
check the account used has the right role/privileges to access this menu item
check your cisco.com credentials is configured and valid
System -> Settings -> Cisco Accounts -> Cisco.com Credentials
check if cisco DNA center can reach the internet and the specific URL's needed for access to updates
Cisco DNA Center First-Generation Appliance Installation Guide, Release 2.2.3 - Plan the Deployment [Cisco DNA Center] - Cisco
09-11-2023 07:27 AM
I don't have Cisco DNA covered under my Cisco ID then I won't be able to do an upgrade?
09-11-2023 08:05 AM - edited 09-11-2023 08:10 AM
that's partially right
it will not work with GUI procedure because DNA itself cannot login to access the download.
you may search for an off-line/ air-gap upgrade.
download the upgrade file, copy to the appliance and start the upgrade from the CLI
But I have no experience with that.
if you somehow can retrieve the image and "burn" it on an bootable USB drive (see installation guides)
you can re-image (not upgrade) the appliance with the new version
found this post: Solved: DNAC Offline Upgrade - Cisco Community
but you need to register a TAC case for that (which implies you need DNA covered under an agreement)
