ISE PxGrid and DNA Center
SecurityEng99
Does Cisco ISE use the "Admin" certificate to connect to DNA Center  ? not the PxGrid certificate ?
What is the different between PxGrid Server and Client certificates ?
The Pxgrid cert is used to modify/create/delete Pxgrid subscriptions via ERS config API’s.
As part of ISE integration workflow, Catalyst Center would check if any existing Pxgrid subscribers are present ( via Pxgrid ERS API) and delete them. After this, it will create Pxgrid subscription via Pxgrid ERS API.
For any ERS Pxgrid API, Pxgrid certs are used for validation.
balaji.bandi
here is the process : ( ISE and DNAC are integrated is via ERS and pxGrid)
 check below thread :
https://community.cisco.com/t5/cisco-software-discussions/ise-3-2-connecting-to-dnac-2-3-3-6-pxgrid-certificates/td-p/4788325
Good video explain :
https://www.youtube.com/watch?v=dKy9SYo0LvA
BB
Watch this video to learn how to integrate Cisco ISE with Cisco DNAC. Other Cisco Enterprise Networking YouTube Channels: http://cs.co/sda-youtube http://cs.co/routing-videos http://cs.co/ise-videos http://cs.co/dnac-youtube http://cs.co/EN-Programmability-Videos
Thanks for the information, but my question is about that ISE using "Admin" certificate to connect to the DNA Center. So what is PxGrid certificate is used for ?
