Maglev CLI - scattered prompt
pielunswe
Hi!
Need some advice regarding scattered promt when login to maglev @ 2222 from computers. Can not type anything and no other command (eg. ctrl + keys) works. Maybe some one knows any command to test?   (have tried with putty, securcrt, terminal and some other app) I do have access to CIMC and the KVM where it seems to be normal promt for maglev if I can restart any service.
Thanks in advance.
6 Replies 6
pieterh
if this was serial connection I'd expect data/bit/parity do not match , but this is telnet/SSH
either your terminal setting is not set to ANSI or VT-100,
or the maglev does not detect the setting of your terminal program properly
Tomas de Leon
I have not seen this issue, but here are two examples when using iTerm2 & secureCRT applications on a MAC device.
in terraterm try different settings in this item->  I think  setting CR+LF when receiving (unix-style) new-line wil improve your output
pielunswe
Thanks for reply. Tried the examples you gave guys but no luck. It's from multiple computers as well, with same settings that worked before. So I suspect DNA side, but unsure what to do. Restart any service related to "maglev"...if there is any....
What is your current Catalyst Center Release version?
pielunswe
2.3.5.5.  DN2 XL
