mdns-sd gateway on 9300 without DNA
corygrifn
I've found some really good value used 9300s from a reputable used kit supplier (I've bought lots of Dell servers and 3850s from them before).
On my 3850s I use service-routing mdns-sd to manage Bonjour between VLANs quite happily (although a little clunky). On 9300 I believe it's now mdns-sd gateway (which I didn't manage to get working on 3850) but it seems to require DNA Advantage.
From what I've read, getting DNA Advantage on a non Refresh used switch requires an expensive re-license.
Is there any way round this at all? I don't need wide area Bonjour, no DNA server etc. Just need gateway between VLANs. Hoping I've misread and local SG can be run without DNA!
If it's not feasible then I'll get some more 3850s instead.
Many thanks in advance
balaji.bandi
you can also get network advantage license to work that. (this is not required DNAC Server or DNA License).
if you investing on again 3850 - product get soon end of life, so for Long Live you need to go to Cat 9300.
BB
