PAT Question
NaderH
What is incorrect with the configuration of PAT for R1 and R2? I am unable to ping the server from f0/0 on R2. The router configuration files are attached to this post.
Martin L
the file is not attach; u must use zip file to be able to attach it to this post
Regards, ML
**Please Rate All Helpful Responses **
Torbjørn
Hello @NaderH,
You seem to be missing the configuration of a nat pool(if you intended to use one). You currently only have a DHCP pool configured.
ip nat inside source list 1 pool RoomA_Pool overload
ip nat pool RoomA_Pool {start ip} {end ip} prefix 24
 Alternatively you can use the interface IP address
ip nat inside source list 1 interface {outside interface} overload
 You can read more about NAT in the following config guide: https://www.cisco.com/c/en/us/td/docs/routers/ios/config/17-x/ip-addressing/b-ip-addressing/m_iadnat-addr-consv-xe.html
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
