PNP for 9800 WLC using Service port
ANKUSH_SINGLA
Hi All,
I am having C9800-L-C-K9 and trying to provision using pnp in DNAC center.
WLC SERVICE PORT is connected to access layer switch via trunk. WLC got IP using DHCP and joined DNAC but when i try to claim device in PnP its not showing Interface to select.
can someone confirm if there is anything i am missing ,or its not supported to claim device using Service port.
i have attached DNAC snip where port is not showing and config on service port at WLC side.
8 Replies 8
balaji.bandi
As per I know WLC controller should be in shared Service
when you mentioned Access Layer ( Fabric Edge Access Switch ?)
BB
ANKUSH_SINGLA
HI Balaji,
Access layer is L2 level switch. we have setup like <Router >>Core Switch (L3)>>Access layer (L2 switch) >>WLC (9800)
when you say shared service does this mean that DNAC should see that SP while claiming device ??
is this Sd-Access Fabric ? or a traditional non-fabric network.
BB
its non-fabric network
As suggest required TAC involvement.
BB
Preston Chilcote
According to the Cisco DNA Compatibility Matrix, PnP of 9800 WLC's is not yet supported
https://content.cisco.com/compatibilitymatrix.html
Good news, I think the matrix is just out of date.  I'll follow up on getting that updated. I have some inside intel that this is supported as of IOS-XE 17.3 and Cisco DNA 2.1.2
If you are using those minimum versions and still not seeing any interfaces in the dropdown list, please make sure you have the correct cli and snmp (read and write) credentials applied to the site.  If you need more help, I recommend a TAC case.
ANKUSH_SINGLA
 Sure Preston, Balaji, i will raise TAC Case, WLC is right now running on 17.3.2a and DNAC version is 2.1.2.5.
