Problem with Nexus 6.2.16 upgrade
shib.sanyal2015
Hello Team,
Recently I have faced a problem during the upgrade of Nexus 7K from 6.2.8a to 6.2.16. When reload the admin VDC, after changing boot-path from 6.2.8a to 6.2.16 ,its returning previous image (6.2.8a), not taking the new one (6.2.16). But in sh boot command its showing the new image after reload. What would be the cause of the issue ? Please suggest. (Looks like all other hardware, BIOS. memory circumstances are OK).
Mark Malone
Is the md5 correct and the image did not get corrupted , thats what i would check as that would cause it to go back to the original image ,use command below and check the value based on the image you downloaded on Cisco website , if its the same your good and you can rule that out to start with
show file bootflash:n5000-uk9-kickstart.7.0.6.N1.1.bin md5sum
60ea0c2ed1128cb0e50b4b40dc2731c8
Thanks for reply but checked MD5 value for Kickstart and System images. All looks fine. We have Dual SUP2E, both SUP is having the image 6.2.16. But its still not worked. Remember we did not implemented ISSU for IOS upgrade. It was disruptive, change the boot system and reload. Please suggest.
did you capture the console output when you rebooted the switch , that will have the answer as to why it didn't load if it was a hard reboot as it would show when it went to load the new image and then what happened , without that its only guessing.
