Smart license
sujanyakj
ISE is using smart licensing and we recently upgraded it to version 2.7 from 2.4.
Observation: In the licence tab, base license last authorization column is not showing any authorization date, which is working fine in tacacs and vm license.
We able to see the radius stop and start logs in the ISE report.
Please suggest on the above issue
with below explanation you can find, base license does not expire.
https://community.cisco.com/t5/network-access-control/ise-licensing-renewal/td-p/4059609#:~:text=%40bluesea2010%20ISE%20Base%20licenses%20generally,delete%20your%20permanent%20Base%20licenses.
Good luck
KB
Hi Kasun,
Thanks for the response. Just one query, if the authorization renewal requeat fails in ISE would it cause any issues.
