SNMP walk to Catalyst Center timing out
SingularTruth
We have a fresh DNAC 2.3.5.5 deployment in 1+1+1 DR.
I've added the SNMP v3 configuration in Settings --> External Services --> Destinations --> SNMP tab
I can walk to any switch or other kit in our estate but not to the DNAC servers.
I've confirmed the auth and priv passwords and other settings are correct. Any thoughts?
Thanks in advance!
Torbjørn
That menu is only for SNMP trap configuration, such that your Catalyst Center can alert a monitoring system of events. I don't believe the Catalyst Center/DNA Center currently supports being monitored through SNMP other than this trap functionality.
You should be able to achieve simple monitoring of server stats through configuring SNMP on the CIMC.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Torbjørn
Hello Torbjorn, Thank you.
No problem @SingularTruth
