System variable "__device.platformId" not available at day-0/PNP?
KristofB
Why is system variable "__device.platformId" not available for OnBoarding day-0 Templates?
When a new device appears in Plug And Play inventory, all kinds of information is available;
   Product ID : C9300-24P
   Neighbors Detail:
        Device Name:  xxxx
        Interface name: xxxx
So I would expect that we can use all this information to help build our Day-0 template.
For example, I wanted to use the platformId to determine the number of stack members and define how many ports are available;
{% for Platform in __device.platformId.split(',') %}
   {% if '24' in Platform %}
      {% set LastPort = 24 %}
   {% elif '48' in Platform %}
      {% set LastPort = 48 %}
   {% endif %}
interface range GigabitEthernet{{ loop.index }}/0/1-{{ LastPort }}
 description It Works
{%endfor%}
I'm not sure if this is the best way to achieve what I need, but it seemed like a logical approach to me.
However, I’m getting the following error:
What’s frustrating, though, is that after onboarding, the provisioning status shows as “Success”, even though the Day-N template hasn’t actually been applied yet.
Only when you manually trigger a provision on the device does the Day-N template get applied.
Thanks!
Torbjørn
Hello @KristofB,
This is a known limitation in onboarding templates as described in the user guide: https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/catalyst-center/2-3-7/user_guide/b_cisco_catalyst_center_user_guide_237/b_cisco_dna_center_ug_2_3_7_chapter_01000.html#onboarding-templates-or-day-zero-t...
You will either have to supply the required information as a variable or handle it with an EEM applet during provisioning
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
KristofB
Sorry I pasted the error image on top of sentence;
"Using the exact same script in a day-N template works just fine."
Torbjørn
Hello @KristofB,
