The DNAC do not show APdata in Device 360
Bill lo
Hi commulity
Our DNAC version is 2.2.3.5
begin 2023/04/04 , the Device 360  is no data From AP:
and we have allready  done "Update Telemetry Settings" on WLC :5520 (with Force Configuration Push option),
still no use; but from WLC , it display Certificat problem:
it's show the Assurance CA certificate is Expired; is it mean we should renew the CA cert on the DNAC ? and how to do that?
thx
Bill
JPavonM
@Bill lo yes you need to renew it through 'Update Telemetry' and then select the 'Force push' option to send everything including the certificate.
I had the same issue a month ago and then not all config were pushed to WLC (C9800) and after some investigation TAC confirmed this is a known issue, and that is fixed in 2.3.3.7.
