Upgrading switch using DNAC
mhernandez
Frequent Visitor
Frequent Visitor
Hi All,
Recently I upgraded a 9400 switch from 16.12.2 to 17.8.1 using DNAC; everything is good with that.
After that, we noticed with a show module that Fw version was not upgraded as well:
The question is: how can we control this via DNAC? Is something from the procedure we missed?
Thanks in advance
Preston Chilcote
I think you will need to issue the “upgrade rom-monitor capsule golden switch rp active” command which will upgrade the ROMMON for all cards and needs a reload to take effect.  If that works, please use the Make a Wish feature in the Cisco DNA help menu to let product management know that the SWIM process is missing a step for 9400 platform.
Leo Laohoo
16.12.2r is the ROMMON.
9400 Sup1/Sup2 do not support manual ROMMON upgrade.
9400 Sup1/Sup2 do not support manual Golden Capsule upgrade.
