02-16-2024 08:52 AM
Hello Cisco community. My organization is set on reloading our access switches annually and I'm tasked with determining a way to ensure this is done. I have used Cisco Prime to run a job using the CLI templates available there and am looking for a way to do the same via DNACenter. While I am reading through DNAC user guide I thought it best to utilize all the resources available and thought the community a great place to start. My desired outcome is to create an automation that will do a write mem and then reload a series of switches and am hoping someone could give me the steps to get there. Thanks in advance.
02-16-2024 09:03 AM - edited 02-16-2024 09:04 AM
You could leverage EEM to schedule an event that does this and manage it on a template. E.g. a subset to reload at a certain time like the edge and the "core" to reload at another time. EEM event timer is what you need.
02-16-2024 09:14 AM - edited 02-16-2024 09:15 AM
What is need to reload switches ?
you can use EEM Script to reload the switches - run external python script to reboot.
