Wireless sensor association failure "Deauthenticated because Sensor is leaving"
Hi all we are testing a wireless sensor with DNAC.
All test go well, but we stil have reported failures under association.
If I drill down, the failure reason is "Deauthenticated because Sensor is leaving" (see screenshot)
Isn't this normal behavior?
After investigation with TAC DNAC and Wireless engineers we have concluded the issue was only happening on 2.4GHz band.
After disabling band select (WLC 9800) the issue was resolved.
Tomas de Leon
* What is tests are you running in the template on the Sensor(s) with issues?
* What is the the Scheduled values used for the Template (Test Recurring, Details)?
Note: the "Estimate Time for running the template" and compare to the Scheduled time...
"Deauthenticated because Sensor is leaving error" - typically means that Sensor
tried to run a new test template and tries to connect before getting disconnected
from previous test tempate session.
Thanks for your info Thomas.
The actual test that turns red is the onboarding (but onboarding never seems to be an issue)
I scheduled the tests as 'continuous', I now changed it to 45minutes (test duration estimate is 12minutes), I keep you posted on the result.
