WS-C3850-24P OS/Firmaware
QT76
Hi all,
i get a cisco switch, model WS-C3850-24P, and when i'm looking for a OS/firmware update i have to chose between:
but with show version i get just only "WS-C3850-24P". Which one i have to choose?
May be you can try delete all old certs :
no crypto pki trustpoint TP-self-signed
no ip http
no ip http secure
Then config :
ip http
ip http secure
You can issue below command check the ciphers :
show  ip http server all
or you can also configure ciphers you want to :
ip http secure-ciphersuite  ? (give you options)
and when i reload, my config is gone...is very frustrating sometimes..
If you do not read the documents then you will go more fustration.
show version ( check the config register - setup correctly to retain the config).
config-register 0x102
no system ignore startupconfig
BB
12 Replies 12
balaji.bandi
Image  is universal so download from below link the stable cisco 5star
cat3k_caa-universalk9.16.12.10a.SPA.bin
https://software.cisco.com/download/home/284455435/type/282046477/release/Gibraltar-16.12.10a
BB
Thanks! Oke Now i have two choices:
CAT3850/3650 UNIVERSAL
or
CAT3850/3650 UNIVERSAL W/O DTLS
Which one? What is he difference?
Pick Universal.
i have provided the image name - cat3k_caa-universalk9.16.12.10a.SPA.bin
BB
thanks, i did. Now i have the newst version cat3k_caa-universalk9.16.12.11.SPA.bin installed. Everything is working but now i cannot access the webui. i get this message:
%WEBSERVER-5-LOGIN_FAILED: Switch 1 R0/0: nginx: Login Un-Successful from host 192.168.13.21 using crypto cipher 'ECDHE-RSA-AES128-GCM-SHA256'
any help? Sorry im just a beginner..
..and when i reload, my config is gone...is very frustrating sometimes..
no ip http
no ip http secure
Then config :
ip http
ip http secure
BB
Thank you!
this resolced the config issue, but i still cannot access the webui, and i get the same response if i change the crypto cypher..
....i solved! i missed this command:
ip http authentication local
Thanks a lot for your help!
sure that is basic setup we expected to configure any one before accessing the GUI
but you are more showing logs about cipher, never showed the config.
Glad all good at end. good luck.
BB
Thank you!
marce1000
  - Doesn't matter, take any of them and or the needed  (downloaded) firmware will be compatible ,
 M.
