Python UCS SDK 0.8.3 - Issue with UcsBackup full state
vesposit
I've discovered an issue with UcsBackup full state in the Python UCS SDK (version 0.8.3).
The code in UcsHandle.py expects "fullstate" instead of the correct "full-state" XML command.
Also, there is a check that the file ends with .tar.gz, but the next check actually prevents any full-state backup to fulfil properly.
I have written a quick patch to fix the issue (attached.)
  Vincent Esposito
0 Replies 0
Cisco UCS X-Series Energy Efficiency Offer
