ericwill
End of Support Notice: Support for the Flex-based Plugin for VMware vSphere has been discontinued.  The HTML based Plugin is recommended as a replacement.
Previous Release Information:
Cisco UCS Manager Plugin is an extension for the vSphere Web Client. It enables virtualization administrators to view, manage and monitor various aspects of Cisco UCS physical infrastructure. The result is a single pane of glass for Virtual Center users to get both physical and virtual infrastructure information for a given hypervisor.
New Features in UCS Manager Plugin 2.0(3):
  • Defect fixes
Supported vSphere Web Client Releases:
  • vSphere Web Client 5.5
  • vSphere Web Client 6.0
  • vSphere Web Client 6.5
Refer to release notes and user guide for more details.
manojmu
Community Member
Hello Phillip,
It's a generic error and cannot interpret much with just that. I believe you are dealing with 2.0.1 plugin and have followed and read the user guide and release notes for the same. The plugin has a TAC support , you can raise an SR. Or you can make the log file available to us for now.
The registration log file will be available at %temp%\VcPlugin on the system where the registration tool is run. Where %temp% is value of the environment variable “temp”.
e.g “C:\Users\Administrator\AppData\Local\Temp\VcPlugin”.
chay2263
I was able to successfully register the plugin using https however, I cannot see the plugin in the web client. If I check the vSphere client, I see it under Manage Plugins. I'm running VCSA 6.0 U3b with a external PSC. I checked the vsphere client virgo log and I have this error:
[java.io.FileNotFoundException: /com/cisco/ucs/vcplugin/service/VcPluginPolicyDefault.xml (No such file or directory)]
[2017-04-19T16:52:57.912-05:00] [INFO ] region-dm-2               o.s.beans.factory.support.DefaultListableBeanFactory          Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@2ff11833: defining beans [GetBladeServiceImpl,UcsRegistrationServiceImpl,GetKvmUrlServiceImpl,PersistorImpl,ServerManageServiceImpl,GetFirmwareServiceImpl,GetNetworkComponentServiceImpl,UcsSummaryDataProviderServiceImpl,UcsFaultsServiceImpl,UcsExceptionTranslatorServiceImpl,ObjectNavigatorVSphereDataAdapterImpl,UcsCommonServiceImpl,LsServerComponentServiceImpl,XMLPersistorImpl,PluginPolicyServiceImpl,UcsRegistrationService,GetBladeService,GetKvmUrlService,ServerManageService,GetFirmwareService,GetNetworkComponentService,UcsSummaryDataProviderService,UcsFaultsService,dataServiceExtensionRegistry,ExceptionService,dataService,uriRefTypeAdapter,vimObjectReferenceService,ObjectNavigatorVSphereDataAdapter,UcsCommonService,LsServerComponentService,userSessionService,PluginPolicyService]; root of factory hierarchy
[2017-04-19T16:52:57.912-05:00] [INFO ] region-dm-2               com.cisco.ucs.vcplugin.service.UcsRegistrationServiceImpl     cleanup call for com.cisco.ucs.vcplugin.service.UcsRegistrationServiceImpl
[2017-04-19T16:52:57.913-05:00] [INFO ] region-dm-2               c.vmware.vsphere.client.usersession.impl.UserSessionServiceImpl   getUserSession called on a missing session.
[2017-04-19T16:52:57.914-05:00] [INFO ] region-dm-2               .a.d.i.BlueprintEventPostingOsgiBundleApplicationContextListener  Sending event to topic 'org/osgi/service/blueprint/container/FAILURE' with properties '{bundle.version=2.0.1, bundle=com.cisco.ucs.vcplugin.service_2.0.1 [385], bundle.symbolicName=com.cisco.ucs.vcplugin.service, exception=org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'PluginPolicyServiceImpl' defined in URL [bundleentry://385.fwk733244429/META-INF/spring/bundle-context.xml]: Invocation of init method failed; nested exception is java.lang.NullPointerException, type=5, timestamp=1492638777914, bundle.id=385}'
[2017-04-19T16:52:57.919-05:00] [ERROR] region-dm-2               org.eclipse.virgo.medic.eventlog.default                     AG0000E Application context creation failure for bundle 'com.cisco.ucs.vcplugin.service' version '2.0.1'. org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'PluginPolicyServiceImpl' defined in URL [bundleentry://385.fwk733244429/META-INF/spring/bundle-context.xml]: Invocation of init method failed; nested exception is java.lang.NullPointerException
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1455)
I have no idea what else to check for or do. Any thoughts?
manojmu
Community Member
Hello Chestin,
We have seen this issue with one of our customer who is also on 6.0 u3. Its one of unique cases since nothing has been changed in plugin w.r.t to the piece of module that is dumping out the filenotfound error. Could you please confirm the below..
1. Are you using Cisco UCS manager plugin for the first time?
2. If Not, Were you using a previous version of the plugin say 1.2.5 on this vCenter before?
3. If Not, Did you upgrade the vCenter to 6.0 u3 recently and upgraded our plugin as well?
4. Is the vCenter installed with an external PSC?
All these are to nail down the problem to a specific version of the vCenter. So a bit of history on your plugin usage would help. We are trying to reproduce this in our lab but so far are not successful.
5. If possible from your end can you try installing the previous version of the plugin.viz. 1.2.5. For this you have to unregister 2.0.1, restart the web client service and register 1.2.5. In case you have done this, please ignore.
6. Can you paste the output of this command here after running the same on the vCenter server shell.
    Go to / (cd /) and execute "find . -name VcPluginPolicyDefault.xml"
Manoj
chay2263
1. Yes this is my first time using it
2. No
3. No
4. Yes. We have two VCSA appliances in linked mode pointing to a external PSC. I only tried to install the plugin on one vCenter however.
5. I can try to install the previous version as I have not tried this.
manojmu
Community Member
Can you please get the result of point 6 as well.
And then please try to address point 5 and let us know if you are able to use plugin 1.2.5.
chay2263
This is the output:
vca02:/ # find -name VcPluginPolicyDefault.xml
./usr/lib/vmware-vsphere-client/server/work/deployer/s/global/148/0/ucs-vcplugin-service.jar/com/cisco/ucs/vcplugin/service/VcPluginPolicyDefault.xml
find: `./var/lib/ntp/proc/11058': No such file or directory
find: `./var/lib/ntp/proc/11059': No such file or directory
chay2263
Got this also when ran with a ".":
vca02:/ # find . -name VcPluginPolicyDefault.xml
find: `./proc/29747': No such file or directory
find: `./proc/29748': No such file or directory
manojmu
Community Member
Thank you chestin. This is as expected and was to confirm if file is not there. But that is not the case and the analysis should continue. I have initiated a discussion with VMware but as of now no breakthroughs there as well. Meanwhile you can try 1.2.5 plugin. For this please
1. Unregister the 2.0.1 plugin
2. Restart web client services using the commands
    service-control --stop vsphere-client
    service-control --start vsphere-client
3. Register the 1.2.5 plugin
chay2263
I tried the 1.2.5 plugin and it still doesn’t work either. I guess I’ll just have to wait for an official fix with Cisco and VMware
eelco.driel
At the moment I'm implementing the plugin at a Vmware 6.5 environment with a VCSA vCenter setup. When deploying the plugin 2.0(3) the registration tool succeeds. However, after restarting the VCSA services the plugin isn't shown inside vCenter. However, when I look at https://vcenter/mob it shows that the plugin is deployed.
It looks like that the installation of the plugin isn't going correctly. A different environment contains also the plugin and this one is working normally. I also get a reply back when executing the command (at the working environment):
find . -name VcPluginPolicyDefault.xml. The not working one isn't showing this file.
Does someone knows how I can show the plugin?
Thanks.
eelco.driel
The plugin isn't doing a check during the deployment towards the vCenter server. I got a successful deployment, but at the end the plugin wasn't copied to the vCenter server because of a firewall.
AbteenZ
Hi Team -
I've registered the UCS vcenter plugin and everything seems fine. After restarting the web client service I also see the event logs that shows the process was successful. But in the web client I can not see UCS Plugin icon.
I see the plugin available in the mobi page of vcenter.
https://x.x.x.x/mob/?moid=ExtensionManager
Hi All
Is there a version out yet that supports 6.7 ..?
Kr
Paul
