owalsdor
Same like UCS PowerTool Script for UCS C3000/S-Series: Convert all disks to JBOD for UCS Domain(s) this script converts the back-end SSDs and the top-loaded HDDs to Unconfigured-Good for the same environment. Some vendors in Object Storage environments, i.e. Red Hat Ceph Storage uses RAID 0 for each individual disk. The script prepares the disks as it sets them to Unconfigured-Good.
Right now you have to touch each array in UCSM and right click on a bunch of disks to convert to Unconfigured-Good. The script does that step for all disks in a C3260 or S3260 for your whole environment.
P.S.: Thanks to joemar as parts of this script came from his VLAN script.
James Welch
Thanks for this!  I had to modify for standalone servers, but it worked great.  It is available here.
https://github.com/jamwelch/CIMC/blob/2d2215907f5d19c4d55707a42df33a4c3cdfd446/IMC-S3260-Convert-to-UnconfiguredGood.ps1
