Copy Similar COnfiguration between 2 UCS
venkatevt
I have an existing UCS system with fully configured lot of UCS profile templates and policies, i would like to copy the same config to my new UCS system as well especially service profiles, service profile templates and policies so i no need to create them manually when ever i get new UCS. PLease suggest how i can do it.
Thanks for your time
jomcdono
Hi Venkatadri,
Take a look at one of my blogs from a few years ago, https://blogs.cisco.com/datacenter/synchronize-ucs-objects
There is a newer version of UCS PowerTool than mentioned in the blog, https://software.cisco.com/portal/pub/download/portal/select.html?&mdfid=286305108&flowid=79283&softwareid=284574017
As well the copy and sync Cmdlets may support a few more options.  Check the UCS PowerTool User Guide for the latest compare and sync samlpes, https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/msft_tools/powertools/ucs_powertool_book/2x/b_Cisco_UCSM_PowerTool_UG_Release_2x/b_Cisco_UCSM_PowerTool_UG_Release_2x_chapter_010.html#concept_580AFB4065584F7B973C5C4D6DBF943E
Hope that helps.
John
jomcdono
Hi Venkatadri,
Hope that helps.
John
Cisco UCS X-Series Energy Efficiency Offer
