What is the limitation for frequency to using DNAC API
daxu2
Hi Expert:
There seems that have some limitations of  using api by 5 times/minutes?
It affect our application visualization when we want to frequently get information from dna center.
cloud you tell me how many time slot between  two using api
Thanks!
error message:
  "error" : "Rate Limit exceeded; BapiName: Get Overall Client Health, RateLimit config details: RateLimitContext{rate=5, windowUnit='minute', windowDuration=1, maxConcurrentExecutionsPermitted=0}",
  "bapiExtendedStatusCode" : "REJECTED_ABOVE_THROTTLE_LIMIT",
  "bapiExtendedStatusDescription" : "For BAPI: Get Overall Client Health, maximum allowed BAPI instances per 1 minute is 5. The limit has been reached for the time-window between Tue May 14 05:55:02 UTC 2019 and now"
9 Replies 9
WB9360
We encounter the same problem. We have made a request through TAC to increase this limit or to make it adjustable.
I think Cisco should fix this issue , whats the use of API if its limited this way . ACI APIC does not have this issue  , seems like applicable only for DNAC .
in 1.3.3 the assurance API rate limit has gone from 5/min -> 100/min
Thanks Adam Radford ,
Any news if same will be applicable for intent APIs as well ?
The assurance API is an intent based API.
/dna/intent/api/v1/client-health
dna/intent/api/v1/client-detail
dna/intent/api/v1/site-health
dna/intent/api/v1/network-health
joe.fodor
I am trying to use dna/intent/api/v1/device-enrichment-details and its only 5 requests in 1 minute which sometimes its more and it seems really low.
Anyone know how to increase?
Cedric Metzger
With 2.2.2.5 still only 100 calls per minute for intent/site API. Is there any way to overcome this limitation?
nicklas
Same issue here, 100/minute still... why not make this configurable???
This is a hefty limitation when creating products that integrate with DNA-Center.
There is a solution. Do not use the official API, use the GUI API (e.g https://dnac/dna/provision/devices/inventory/provisioning) you would use as a normal user.
I wrote an entire migration script depending on the User GUI API for C9800 to DNAC managed C9800: https://github.com/itris-one/migrateC9800toDNAC
