hx edge cluster creation
ppnlr
we are trying to to deploy a no FI hx edge cluster. unfortunately for some reason we need to temporarily shut down  the hardwares. can we interrupt the cluster deployment by shutting down the servers. then reconnect it after without data corruption nor starting over again?
RedNectar
Hi @ppnlr ,
I imagine that if you are "trying to to deploy a no FI hx edge cluster" - then there is no data loss to worry about.  But surely there is more detail you can give then "some reason we need to temporarily shut down  the hardwares"
WHY?
Dis you get an error message saying that you had to shut down the hardware? If so, send us a picture.
RedNectar aka Chris Welsh.
its about the site where the servers are..needs to fix on their power supply thus, there would be a power outage  the place is new and no enough power backup yet..
