Target is disconnected from Intersight
kchu
I have Cisco UCSX-210C-M6 servers in Intersight Managed Mode. They are VMware ESXi hosts.
Once in a while I'll get an alarm that a target/server is disconnected from Intersight but it will usually reconnect on it's own and then clear.
A few months ago I had one that did not reconnect on it's own. I had to decommission, reseat, and then recommission it.
Now I have another one that will not reconnect on it's own and Cisco TAC recommends decommission, reseat, and then recommission. The server and all others continue to operate normally.
It seems completely unnecessary to go through that just because of a bug or whatever would cause the disconnection.
Do others have this problem? If so do you have any idea what caused it? Have you had to decommission, reseat, and then recommission?
kchu
After initially recommending to decommission/reseat/recommission, the TAC engineer suggested I first try power cycling the chassis slot, and that did resolved the error.
Shut down the server > power cycle the chassis slot > power on the server
Blade discovery was triggered and the server connected to Intersight.
