02-16-2022 06:37 AM
Can I build the CML VMs on an ESXi host that has internet access, activate / register the product, then export the VMs off the ESXi that has internet access and import it to our air-gapped ESXi host?
thanks
02-16-2022 07:04 AM
it should work as long as VM ID S/N not changed.
02-16-2022 08:24 AM - edited 02-16-2022 09:12 AM
Thanks.
Follow-up Question
Once the VM is moved to to our air-gapped ESXi host and powered on, will the VM ever need to connect to internet again ?
I read on another forum that the CML VM can be disconnect for up to 7 days until you're required to re-authorize.
If this true, we cannot use CML Personal Edition as there is no way to get an internet connection.
